Hi M!
Here is a simple parametric lisp
change to your suit
O
Lee, Cadtutor will be temporary shutdown on weekend so you have lots of time. Don't rush, is weekend: have fun!
Hi M!
change to your suit
O
The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
Lee Mac Programming
Just another Swamper
Thanks Oleg, now I will got time to go on Cadtutor instead of loosing time for drawing. I am so happy now. Will buy bottle today and wait when you coming visit me.
You too Lee (drinking limit in Canada is 19 years of age)
Lee Mac Programming
hi guys....am new here, just a thought... will it be possible to have a lisp like the elbow flex duct except it goes straight and makes elbow too, like the duct lisp and wpipe...it will be great if i could have one lisp like that...![]()
I made this a while back, not sure if it helps or not
Code:(defun c:duct (/ *error* oVars vLst p1 p2 vEnt i PntEve PntOdd cAngE sPtE ePtE cAngO sPtO ePtO last_pt1 last_pt2) (defun *error* (msg) (if oVars (mapcar 'setvar vLst oVars)) (princ (strcat "\nError: " (strcase msg))) (princ)) (setq vLst '("CMDECHO" "CLAYER" "FILLMODE" "OSMODE" "PLINEWID") oVars (mapcar 'getvar vLst)) (setvar "CMDECHO" 0) (setvar "FILLMODE" 0) (if (not (tblsearch "LAYER" "DUCT")) (command "-layer" "M" "DUCT" "_C" "1" "DUCT" "") (setvar "CLAYER" "DUCT")) (vl-load-com) (if (and (setq p1 (getpoint "\nSpecify First Point: ") p2 (getpoint p1 "\nIndicate Direction of Duct: "))) (progn (setvar "PLINEWID" 6) (setvar "OSMODE" 0) (command "_pline" p1 (polar p1 (angle p1 p2) 2.0) "_arc") (while (> (getvar "CMDACTIVE") 0) (command pause)) (setq vEnt (vlax-ename->vla-object (entlast)) i 2.0) (while (and (setq PntEve (vlax-curve-GetPointatDist vEnt i) PntOdd (vlax-curve-GetPointatDist vEnt (setq i (1+ i))))) (setq cAngE (+ (/ pi 2) (angle '(0 0 0) (vlax-curve-getFirstDeriv vEnt (vlax-curve-GetParamAtPoint vEnt PntEve))))) (command "_line" (setq sPtE (polar PntEve cAngE 4.0)) (setq ePtE (polar PntEve (+ pi cAngE) 4.0)) "") (if (and last_pt1 last_pt2) (progn (command "_line" last_pt1 sPtE "") (command "_line" last_pt2 ePtE ""))) (setq cAngO (+ (/ pi 2) (angle '(0 0 0) (vlax-curve-getFirstDeriv vEnt (vlax-curve-GetParamAtPoint vEnt PntOdd))))) (command "_line" (setq sPtO (polar PntOdd cAngO 3.0)) (setq ePtO (polar PntOdd (+ pi cAngO) 3.0)) "") (command "_line" sPtE sPtO "") (command "_line" ePtE ePtO "") (setq last_pt1 sPtO last_pt2 ePtO) (setq i (1+ i))) (vla-put-ConstantWidth vEnt 0.0) (vla-put-Color vEnt acblue)) (princ "\n<!> Points Specified Incorrectly <!>")) (mapcar 'setvar vLst oVars) (princ))
Lee Mac Programming
Or there's this offering from CAB
Lee Mac Programming
Someone over at the swamp has an entire HVAC Lisp program suite, actually. I think CAB has like 3 or 4 different flex LISP.
Tannar Frampton | Facilities Engineering | Revit 2013
Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
I think TimSpangler has also got a whole suite - posted somewhere on here.![]()
Lee Mac Programming
