Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2009
    Sep 2008
    3
    Default Middle button pan and right button object drag doesnt work
    Hi,
    Recently Ive lost the ability to drag objects by holding the right button. Also, when I select the object and right click, the move command on the shortcut menu does not appear.
    I did try to fool around with the CUI to try and restore the scroll button panning (this error occured a while ago but I decided I could live without it). And now for some mysterious reason the right button drag doesnt work.
    Also, when I press del, the objects dont delete anymore.
    This is all a mystery to me. I have tried to restore the CUI defaults, but to no avail.
    please help
    Henry - Civil Engineer
    Forum Newbie
    AutoCAD 2009
    Sep 2008
    3
    ps. also ive tried fooling around with the mouse settings by setting everything to default. Again, no avail.
    Plus this doesnt explain why I cant delete using the del key anymore!
    Forum Newbie
    AutoCAD 2009
    Sep 2008
    3
    Ah I've found the solution on this forum.
    pickfirst 1
  1. Middle Mouse Button Pan
    By JaketheMan in forum AutoCAD General
    Last Post: 30th Oct 2007, 07:46 pm
  2. Middle button....in LISP
    By pefi in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jul 2007, 11:24 pm
  3. Setting middle mouse button as F3 button
    By alerch in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2006, 10:04 pm
  4. Middle mouse button.
    By ceno in forum AutoCAD General
    Last Post: 30th Mar 2006, 10:46 pm
  5. middle button on mouse?
    By hughesey in forum AutoCAD General
    Last Post: 11th Oct 2005, 03:28 pm
