Plotting only thin lines
ALLI
Okay I've just spent 1/2 hour searching forum to find a solution, I may have miss it, but it's all beginning to blur!
I am using default LWT and CTB plot styles, but my drawing is printing out all thin fine light types, their should be some thick & some thin lines.
I'm not scaling LWT in the plot menu, I have made sure they are default in the layer manager & the objects are set to LWT bylayer in the drawing.
The drawing was not set up by me, so it is in model space only.
Can anyone see what is happening?
Ta
Sounds like you need to edit the lineweights in the .ctb file; Stylesmanager command and dbl-clk on the .ctb file you want to use
Sorry for being a pain, but after opening the dwg in 2004, and printing it, it now works in 2009, :unsure:, go figure, problem solved and I don't know how.
