Results 1 to 9 of 9
Thread: Script problem
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    321
    Default Script problem
    Hi,
    I want to replace a block in a set of drawings with a script file. When I tried entering the commands on the command line with _insert autocad asked if i wanted to redefine the block. But when I use the script below to script is crashing because where Iam expecting the question whether I want to redefine the block autocad is actually looking for an insertion point. Is there something I am missing? Any ideas welcome.
    thanks
    Code:
    _-insert
    D:\Personal\CAD\Research\titleblocktext_att.dwg
    _yes
    0,0
    _erase
    _L
    attsync
    n
    plankopf_att_neu
    _qsave
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 2000
    Quadro fx500
    2x 1920x1080
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD pre 2000
    May 2008
    Rockford, Illinois
    588
    Look into including the "EXPERT" sysvar into your script before issue the command in question. Something like:
    expert
    2
    expert
    0
    You will also want to reset it afterwards.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
    Full Member
    AutoCAD 2007
    May 2008
    54
    How about, renaming the existing block before inserting the new block?
    peace out
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,070
    that is certainly how I do it. Are you sure the "new" block resides in the drawing already? It sounds like its not there so doesn't need redefining.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  5. #5
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,015
    Quote Originally Posted by feargt View Post
    Hi,
    thanks
    Code:
    _-insert
    _yes
    0,0
    _erase
    _L
    attsync
    n
    plankopf_att_neu
    _qsave
    when i type "insert" you will not get the same prompts as when you (command "insert"). the command way will prompt you for xyz coords, etc.
    you could just write it to only execute if it finds the block in your drawing:
    Code:
    (if (tblsearch "block" "titleblocktext_att")
     ;**insert your code here
  6. #6
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    321
    So thank you for all the assistance. There was no one answer that did the trick. Was more of a combination of things. Below is the script that worked for me
    Code:
    attdia
    0
    attreq
    0
    expert
    2
    _insert
    plankopf_att_neu=D:\Personal\CAD\Research\plankopf_att_neu.dwg
    0,0
    1
    1
    _erase
    _L
    attsync
    n
    plankopf_att_neu
    expert
    0
    _qsave
    Thanks again for taking interest in this one. Always appreciated.
  7. #7
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,070
    I forgot about the = method. With that you are telling AutoCAD that the block must be redefined so I don't think you need to fiddle with the expert setting.
    Dave
  8. #8
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    321
    Just wanted to be on the safe side
  9. #9
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    Electro/Mech
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,070
    Dave
  1. PDF Script
    By SeaRR85 in forum AutoCAD General
    Last Post: 3rd Dec 2008, 02:30 pm
  2. Script in cad
    By Insener07 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2008, 02:36 pm
  3. Script problem
    By Rooster in forum AutoCAD General
    Last Post: 2nd May 2008, 06:39 pm
  4. Sub script and Super script Text
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2007, 08:07 pm
  5. funny problem about command "section" in a script
    By phymilton in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2006, 03:36 am
