NLClause Posted March 30, 2009 Share Posted March 30, 2009 Weird problem i go and draw out my parcel with a pline. I go to the top pul down and select create parcel from object. I go in select all of the options in there and what pops up is not right. It is labeling the parcel with inch dimensions and putting the foot symbol after it. I need them to be in feet. I have tryed to attach whats going on but the file is to large every way i try. If any one can help it would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 And i just realized I posted this in the wrong section. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 30, 2009 Share Posted March 30, 2009 I've moved your question to the Civil 3D section. :wink: Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 Thank you. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 30, 2009 Share Posted March 30, 2009 In Toolspace > Settings rt-clk on the drawing name (probably at the top). Select Edit Drawing Settings. Your Drawing units should be in Feet. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 They are. Ive tried that about 20 times. All of this I did in the master view. Also when i input the lengths, they automatically are in inces i have to go in and put a foot symbol in does that have any thing to do with what is going on ? Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 30, 2009 Share Posted March 30, 2009 it's in the settings in toolspace. check under dimensions/distance, can't remember what it's called. i had the same problem with dimensions not interpreting correctly. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 I cant find that label any where down the tree. I did just figure out that if i draw the object and dont put a foot symbol after the distance, the line is in inches. When i dimension, it shows up as like 8' 3.55" then when I create parcell from object it puts the label on as 99.55'. that cant be right. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 30, 2009 Share Posted March 30, 2009 I cant find that label any where down the tree. I did just figure out that if i draw the object and dont put a foot symbol after the distance, the line is in inches. When i dimension, it shows up as like 8' 3.55" then when I create parcell from object it puts the label on as 99.55'. that cant be right. i'll check as soon as i get to work. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 30, 2009 Share Posted March 30, 2009 Maybe here? Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 this is what my setting was at. should i change it. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 This is what its looking like. Quote Link to comment Share on other sites More sharing options...
rustysilo Posted March 30, 2009 Share Posted March 30, 2009 What does it show when you type in UNITS? Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 This is what my instructor told me to have in there so I hope this part is right. Dont you love when a school has someone teaching something that they have no clue about. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 30, 2009 Share Posted March 30, 2009 It might be something in your Dimstyle. Open up Dimension Style Manager and check your Primary Units tab. Try setting your units to Decimal instead of Engineering. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 But when turning in to a parcel those labels are not a dim style are they? Just because i have no idea which dim style it would be using. And it makes it part of the pline I have to xplode it to get rid of the parcel. Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 I created a copy of the standard Dim style and changed it to decimal. Only effect is that when I create a normal dimension it uses decimal. Quote Link to comment Share on other sites More sharing options...
EMS_0525 Posted March 30, 2009 Share Posted March 30, 2009 Its got to be in your dimstyle... Quote Link to comment Share on other sites More sharing options...
rustysilo Posted March 30, 2009 Share Posted March 30, 2009 It might be something in your Dimstyle. Open up Dimension Style Manager and check your Primary Units tab. Try setting your units to Decimal instead of Engineering. That was my next thought. We always use decimal units instead of engineering. Is that dim in paperspace? If so, what's the viewport scale? Quote Link to comment Share on other sites More sharing options...
NLClause Posted March 30, 2009 Author Share Posted March 30, 2009 No, they are in model space. It happens with the parcel. My normal dimensions are fine. Quote Link to comment Share on other sites More sharing options...
