Results 1 to 9 of 9
    Forum Newbie
    LDD 2009
    Mar 2009
    3
    Default Viewport on No-Plot still showing border line?
    My rectangular viewports are set to no-plot. However, when I do a print preview, the bottom "border line" shows up! This only happens on certain plotters in my office though. This happens when I try to plot a half-sized drawing. When I send it to the big plotter, the line disappears like it is supposed to. It matters because we give half-size plots to our clients.
    Any ideas? Thanks!
    Senior Member CADgirl's Avatar
    Structural
    CADgirl's Discipline Details
    CAD Drafter, Seismic Retrofitting
    Structural
    AutoCAD 2018
    Nov 2006
    Orange County, CA
    278
    This is just a shot in the dark here but whenever I have a weird problem I always try purge and audit. And it sometimes works.
    "All I've ever wanted was an honest week's pay for an honest day's work."
    -Steve Martin
    Full Member DECHAL's Avatar
    DECHAL's Computer Details
    Windows XP
    Dell Precision Laptop
    Intel ?
    21" Flat Screen (Dell)
    AutoCAD 2013
    Jan 2009
    Ireland
    71
    When I do not want to plot certain objects - Lines - etc. I put them onto a layer and switch the icon in the layer manager to "do not plot".
    Maybe worth a short.
    Regards,
    DECHAL
    Forum Newbie
    LDD 2009
    Mar 2009
    3
    Quote Originally Posted by CADgirl View Post
    Neither worked. I've never heard of the 'audit' command though, so thanks for that tip anyway!
  5. #5
    Forum Newbie
    LDD 2009
    Mar 2009
    3
    Quote Originally Posted by DECHAL View Post
    The viewport is already on "do not plot." And as I said before, when I plot full-size, the line goes away. And its only happening on some of the drawings in the project, not all of them. This is so frustrating...
  6. #6
    Structural
    Structural
    AutoCAD 2018
    Nov 2006
    Orange County, CA
    278
    I don't know how you have your paperspace set up but I have it where it shows the paper size. I had a drawing where there was a line right along the paper shadow, so you couldn't see it until I did a plot preview or when it plotted. Could there be any hidden lines in your drawing?
    -Steve Martin
  7. #7
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    Win 7 (64-bit)
    HP h8-1070t
    Intel Core i72600
    12GB
    AMD Radeon HD 6850
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2012
    Dec 2008
    Lebanon, PA
    749
    If it is only one viewport doing this why not delete it and recreate it, either by drawing a new one or copying one without this anomaly and setting it to match.
    Just because you're , doesn't mean wrong is all that's .
  8. #8
    Forum Newbie
    AutoCAD 2010
    Jun 2011
    1
    Default remove View port lines
    I think I may have found the answer to removing the view port lines.
    You have a few different View ports in paper space in layout one for instanse.
    You print and the box shows up around each view. To remove lines change the Color of the boarder of the viewport, change it to Red or a Color that is not being used.
    Every red item will be transformed to something else.
    Start the print process and click on the PEN STYLE ASSIGNMENT BUTTON TOP RIGHT CORNER None is selected, change it to acad.ctb. Click edit button. Go down to line type and choose Sparse dot.
    Don't change anything else and it seems to work. save and close.
    I'm using AutoCad 2010
    Now choose preview and the lines should be gone.
    I'm printing to .pdf file.
    If it works tell me!
  9. #9
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2018
    Feb 2010
    Oviedo, Florida
    4,759
    Quote Originally Posted by jcarl1313 View Post
    Any ideas? Thanks!
    You may have the printable area edge inside your viewport when you print to the halfsized paper. Sometimes AutoCAD will generate a line where the edge of the printable area is encroached upon, don't know why. On the full sized page you are probably plotting LAYOUT. Betcha you are plotting EXTENTS or WINDOW when shrinking to the small paper and not taking account for the paper size properties. The non-printable margin is just as wide there as on the larger paper. It is a physical limit, not a percentage of the given paper size. I have occasions to print 24x36 on 11x17 often, but I have a whole separate set of layouts for it. My non-printable area is roughly 3/8" wide on both sheets, so I had to adjust the viewports on the 11x17 sheets a little to fit inside the non-printable area on them.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  1. problem with viewport border
    By Dipali in forum AutoCAD General
    Last Post: 27th Jun 2008, 08:06 am
  2. viewport border removal?
    By AutoNewbie in forum AutoCAD Beginners' Area
    Last Post: 17th Jun 2008, 03:32 pm
  3. Drawing Border (Text not showing correctly)
    By Ste1978 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Mar 2008, 05:57 pm
  4. Viewport border thickness?
    By scottj1982 in forum AutoCAD Drawing Management & Output
    Last Post: 7th Aug 2007, 05:59 pm
  5. Viewport Border Visibility
    By Barry Clark in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jan 2005, 10:47 pm
