Results 1 to 7 of 7
    Full Member
    not specified
    Dec 2004
    Sydney, Australia
    29
    Default Selection highlighting changed to solid not dashed
    Midway through my session I must have hit some key combination that changed a global setting of some sort as all of a sudden when selecting objects they no longer show up dashed to show they are selected, the grip points still show but there is no dotted line of the objects.
    This happens everywhere including when picking boundaries to hatch......you cant see what boundaries you have seleced because the selection line is solid.
    This is making life unbelievably difficult, does anyone know how to reset the selection to a dashed line as opposed to a solid line?
    Incase I am not being clear, draw a line. Then select it (click on it) and you see it becomes dashed and the grips appear. When I select now just the grips show up and the line stays solid.
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    It could be your HIGHLIGHT system variable
    Full Member
    not specified
    Dec 2004
    Sydney, Australia
    29
    Quote Originally Posted by CarlB View Post
    you sir are a genious! Im sane again.
    Super Member GE13579's Avatar
    GE13579's Computer Details
    Windows XP
    Fujitso Siemens
    3.4Ghz
    Samsung 19" TFT
    Mechanical 2009
    Feb 2007
    North East England
    1,454
    Another option is to go to OPTIONS- Selection tab then hit the "Visual Effect Settings..." button- this will give you a couple more options to try out also.
    "To alcohol; the cause and solution to all of life's problems." - Homer Simpson
  5. #5
    Forum Newbie
    Architecture 2008
    Jan 2009
    2
    another problem solved thanks to my favorite forum!! 'preciate it cadtutors!
  6. #6
    Forum Newbie
    AutoCAD 2010
    Jun 2011
    4
    hi guys I'm new here...i have same problem i tried highlight=1, it works but when i open any cad file still the same problem...guys pls help me..thanks in advance.
  7. #7
    Full Member
    AutoCAD 2010
    Jun 2010
    36
    I know I am some 2 years late with this reply aldooliquino, but I have noticed that even with HIGHLIGHT = 1, when you select lines with a linetype that is "dashed", the highlight effect is not apparent. I suspect you were selecting dashed line. Could always be wrong tho...
  1. highlighting
    By rookie37 in forum AutoCAD General
    Last Post: 7th Aug 2008, 03:55 am
  2. --- dashed lines look ___ solid in layout view
    By ann in forum AutoCAD Drawing Management & Output
    Last Post: 19th Jun 2007, 07:07 pm
  3. Highlighting Text?
    By daiharv in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2007, 02:05 pm
  4. 2007 - solid selection problem
    By maxholer in forum AutoCAD General
    Last Post: 19th Apr 2006, 01:23 pm
  5. Highlighting problem
    By paulmcz in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Nov 2005, 03:56 am
