Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    AutoCAD 2007
    Oct 2008
    6
    Default Wrapping text around an arc or circle
    I'm trying to wrap text around an arc to create an emblem. Can't find a way to get the desired effect. The only methods that I thought of were a polar array, and an oblique slant, but failed.
    I'm trying to recreate the USCG emblem, and need to wrap the text around the arc in the center of the symbol.
    Any helpful hints would be appreciated.
    Senor Dorado
    Super Member skipsophrenic's Avatar
    skipsophrenic's Computer Details
    Vista 32 bit
    Compaq
    erm . . yeah?
    Intel Pentium Dual CPU E2140 @ 1.60 Ghz
    2039MB
    don't ask you'll kill me
    360gb
    21" widescren - 16:10 ratio
    AutoCAD 2008
    Jul 2008
    Birmingham, United Kingdom
    1,020
    ARCTEXT command sounds like what u're after.
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
    SET FILEDIA = 1
    Forum Newbie
    AutoCAD 2007
    Oct 2008
    6
    ARCTEXT is an unknown command in 2007 revision. Am I entering the command incorrectly?
    Senor Dorado
    Super Member chulse's Avatar
    chulse's Computer Details
    Windows 7
    Lenovo W701 mobile workstation
    12GB
    NVIDIA Quadro FX 3800M
    17" wide screen laptop w/ 22" acer
    See details...
    chulse's Discipline Details
    Conservation Planner/Arborist
    See details below.
    Tree Preservation Planning for civil design and developent
    Civil 3D 2013
    Jul 2007
    Front Royal, Virginia
    1,312
    Is Express Tools loaded?
    Cary Hulse
    www.TreePreservationPlan.com
    www.Pack53.info
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Just to add to the above...
    Express > Text > Arc Aligned Text.
    If you did not load Express Tools when you loaded 2007 initially you can go back to your installation CD and correct that oversight.
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    If you did not load Express Tools you can also
    Create a block - say of the letter T
    Use the DIVIDE command with the BLOCK option.
    Go back and edit each letter as desired.
    This method will also follow polylines and splines.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  7. #7
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Load Express Tools, easy enough.
    From the "Express" drop down menu, "Arc-Aligned Text."
    That was easy! Take a peek-a-boo at the attached *.dwg.
    AutoCAD '07 Express Tools like ReMark states above.
    Of course, edit as desired.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  8. #8
    Forum Newbie
    AutoCAD 2007
    Oct 2008
    6
    Default Thanks
    Thanks to all for your help.
    Tankman, I am downloading your dwg. Thanks!
    Senor Dorado
  9. #9
    XP Pro SP3
    IBM T60 Thinkpad™
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Quote Originally Posted by Senor Dorado View Post
    Senor Dorado
    Great! Be sure to post your USCG *.dwg file when you finish!
    Tankman
  10. #10
    Super Member dumfatnhappy's Avatar
    dumfatnhappy's Computer Details
    Windows 7 64 bit
    3.6 dual quad core
    24 gig
    Quadro FX 1700
    269?
    twin 24" flat panels
    Mechanical
    dumfatnhappy's Discipline Details
    mechanical design (Petro-Chem)
    Mechanical
    Process piping (3D)
    MEP 2013
    Oct 2007
    Apollo Beach, Fla
    659
    Quote Originally Posted by Tankman View Post
    awesome, that's my old alma mater! served 81-85. best 4 years of my life! woo hoo!
    that's me on the bow...
    dum
    'Suppose you were an idiot. And suppose you were a member of Congress.. But I repeat myself.'
    --Mark Twain
  1. Wrapping Text?
    By marinebro0306 in forum Autodesk Inventor
    Last Post: 5th Jan 2010, 04:47 pm
  2. Wrapping sheet metal over fixture shape
    By Taryon in forum Autodesk Inventor
    Last Post: 28th Apr 2008, 08:47 pm
  3. Circle Text
    By CADgirl in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2007, 10:35 pm
  4. Circle Text
    By Perto in forum AutoCAD Drawing Management & Output
    Last Post: 26th Oct 2006, 05:14 pm
  5. Text around a circle
    By Tara in forum AutoCAD General
    Last Post: 17th Oct 2003, 04:59 pm
