Centre Line not showing
matt4
Hi,
Anyone know how I can get the centre lines to display? I have loaded the linetype but nothing is happening. I assume its a dimscale problem? What scale can I set my dims to?
Thanks
try to reduce your LTSCALE variable, but its a global variable so all linetypes are affected. if you need to edit only that line, select it then edit the line scale under its properties
LineTypeScale - be aware that if you are viewing these lines in modelspace, they
may appear as a solid line, try looking at it through a viewport at a standard
scale.
