Replacing Blocks
SAM_R
I'm working on the elctrical system of a school where we are replacing all the lights. Now the problem is the drawing has the Arch. 2X4 light block in it and I need to replace it with our company 2X4 block, but some of the lights are at 90 degrees and some are some are at 180. When I use blockreplace it puts my block in at 90 on all the old blocks. Is there a way to have them come in turned the right way?
Modification of an old LISP I wrote a while back:
;; Block Replacer by Lee McDonnell
(defun c:brep (/ blk brep ss doc spc i j)
 (vl-load-com)
 (if (and (setq blk (getstring T "\nSpecify Block to be Inserted: "))
      (snvalid blk)
      (or (tblsearch "BLOCK" blk) (findfile (strcat blk ".dwg")))
      (setq brep (car (entsel "\nSelect Block to Replace: "))))
     (if (setq ss (ssget "X" (list (cons 0 "INSERT")
       (cons 2 (cdr (assoc 2 (entget brep))))
         (if (getvar "CTAB")(cons 410 (getvar "CTAB"))
           (cons 67 (- 1 (getvar "TILEMODE")))))))
     (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
           (vla-get-modelspace doc)
           (vla-get-paperspace doc))
             (vla-get-modelspace doc)) i 0 j 0)
     (vla-EndUndoMark doc)
     (vla-StartUndoMark doc)
     (foreach ent (mapcar 'vlax-ename->vla-object
                  (mapcar 'cadr (ssnamex ss)))
       (vla-insertblock spc
         (vla-get-InsertionPoint ent) blk
           (vla-get-xscalefactor ent)
         (vla-get-yscalefactor ent)
               (vla-get-zscalefactor ent)
             (vla-get-rotation ent))
       (if (vl-catch-all-error-p
         (vl-catch-all-apply
           'vla-delete (list ent)))
         (setq i (1+ i)) (setq j (1+ j))))
     (princ (strcat "\n" (itoa j) " Blocks Replaced"
       (if (zerop i) "." (strcat (itoa i) " were on a Locked Layer!"))))
     (vla-EndUndoMark doc))
   (princ "\n<!> No Blocks Found <!>")))
   (princ "\n<!> Replacement Block not Found <!>"))
 (princ))
Actually this is probably better (credit to David Bethel for block definition code):
[b][color=BLACK]([/color][/b]defun c:brep [b][color=FUCHSIA]([/color][/b]/ bdef blk brep ss doc spc i j[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]vl-load-com[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq bdef [b][color=NAVY]([/color][/b]getvar [color=#2f4f4f]"INSNAME"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not blk[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq blk [b][color=MAROON]([/color][/b]getstring t [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\nSpecify Block to be Inserted <"[/color] bdef [color=#2f4f4f]">: "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]cond [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]eq [color=#2f4f4f]""[/color] blk[b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]setq blk bdef[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]and [b][color=BLUE]([/color][/b]snvalid blk[b][color=BLUE])[/color][/b]
                    [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] blk[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
                    [b][color=BLUE]([/color][/b]findfile [b][color=RED]([/color][/b]strcat blk [color=#2f4f4f]".dwg"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.insert"[/color] blk[b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
     [b][color=MAROON]         ([/color][/b]T [b][color=GREEN]([/color][/b]setq blk nil bdef [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]setq brep [b][color=MAROON]([/color][/b]car [b][color=GREEN]([/color][/b]entsel [color=#2f4f4f]"\nSelect Block to be Replaced: "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
   [b][color=NAVY]([/color][/b]progn
     [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]setq ss [b][color=BLUE]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=RED]([/color][/b]list [b][color=PURPLE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=PURPLE])[/color][/b]
       [b][color=PURPLE]([/color][/b]cons 2 [b][color=TEAL]([/color][/b]cdr [b][color=OLIVE]([/color][/b]assoc 2 [b][color=GRAY]([/color][/b]entget brep[b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b]
         [b][color=PURPLE]([/color][/b]if [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=TEAL])[/color][/b][b][color=TEAL]([/color][/b]cons 410 [b][color=OLIVE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b]
           [b][color=TEAL]([/color][/b]cons 67 [b][color=OLIVE]([/color][/b]- 1 [b][color=GRAY]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=GRAY])[/color][/b][b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
   [b][color=GREEN]([/color][/b]progn
     [b][color=BLUE]([/color][/b]setq doc [b][color=RED]([/color][/b]vla-get-ActiveDocument [b][color=PURPLE]([/color][/b]vlax-get-Acad-Object[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
       spc [b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]zerop [b][color=TEAL]([/color][/b]vla-get-activespace doc[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b]
             [b][color=PURPLE]([/color][/b]if [b][color=TEAL]([/color][/b]= [b][color=OLIVE]([/color][/b]vla-get-mspace doc[b][color=OLIVE])[/color][/b] :vlax-true[b][color=TEAL])[/color][/b]
           [b][color=TEAL]([/color][/b]vla-get-modelspace doc[b][color=TEAL])[/color][/b]
           [b][color=TEAL]([/color][/b]vla-get-paperspace doc[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b]
             [b][color=PURPLE]([/color][/b]vla-get-modelspace doc[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] i 0 j 0[b][color=BLUE])[/color][/b]
     [b][color=BLUE]([/color][/b]vla-EndUndoMark doc[b][color=BLUE])[/color][/b]
     [b][color=BLUE]([/color][/b]vla-StartUndoMark doc[b][color=BLUE])[/color][/b]
     [b][color=BLUE]([/color][/b]foreach ent [b][color=RED]([/color][/b]mapcar 'vlax-ename->vla-object
                  [b][color=PURPLE]([/color][/b]mapcar 'cadr [b][color=TEAL]([/color][/b]ssnamex ss[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b]vla-insertblock spc
         [b][color=PURPLE]([/color][/b]vla-get-InsertionPoint ent[b][color=PURPLE])[/color][/b] blk
           [b][color=PURPLE]([/color][/b]vla-get-xscalefactor ent[b][color=PURPLE])[/color][/b]
         [b][color=PURPLE]([/color][/b]vla-get-yscalefactor ent[b][color=PURPLE])[/color][/b]
               [b][color=PURPLE]([/color][/b]vla-get-zscalefactor ent[b][color=PURPLE])[/color][/b]
             [b][color=PURPLE]([/color][/b]vla-get-rotation ent[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]vl-catch-all-error-p
         [b][color=TEAL]([/color][/b]vl-catch-all-apply
           'vla-delete [b][color=OLIVE]([/color][/b]list ent[b][color=OLIVE])[/color][/b][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b]
         [b][color=PURPLE]([/color][/b]setq i [b][color=TEAL]([/color][/b]1+ i[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b] [b][color=PURPLE]([/color][/b]setq j [b][color=TEAL]([/color][/b]1+ j[b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
     [b][color=BLUE]([/color][/b]princ [b][color=RED]([/color][/b]strcat [color=#2f4f4f]"\n"[/color] [b][color=PURPLE]([/color][/b]itoa j[b][color=PURPLE])[/color][/b] [color=#2f4f4f]" Blocks Replaced"[/color]
       [b][color=PURPLE]([/color][/b]if [b][color=TEAL]([/color][/b]zerop i[b][color=TEAL])[/color][/b] [color=#2f4f4f]"."[/color] [b][color=TEAL]([/color][/b]strcat [b][color=OLIVE]([/color][/b]itoa i[b][color=OLIVE])[/color][/b] [color=#2f4f4f]" were on a Locked Layer!"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b]
     [b][color=BLUE]([/color][/b]vla-EndUndoMark doc[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
   [b][color=GREEN]([/color][/b]princ [color=#2f4f4f]"\n<!> No Blocks Found <!>"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
   [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\n<!> Replacement Block not Valid <!>"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]princ[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
That didn't work they are still coming in the wrong way. Any other suggestions.
Hmmm... it must be something to do with your block - the LISP is very simple - just retrieves the insertion, scale and rotation of all the blocks (a sample of which the user selects), and replaces them with a block with the same properties.
See video :)
Block Replace.zip
You can (entmod) DXF group 2 in an INSERT definition for an easy update:
[b][color=BLACK]([/color][/b]defun c:ins2ins [b][color=FUCHSIA]([/color][/b]/ lb bn ss i en ed[b][color=FUCHSIA])[/color][/b]
[color=#8b4513];;;GET NEW BLOCK INFO[/color]
 [b][color=FUCHSIA]([/color][/b]setq lb [b][color=NAVY]([/color][/b]getvar [color=#2f4f4f]"INSNAME"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not bn[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq bn [b][color=MAROON]([/color][/b]getstring [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"\nBLOCK To Insert <"[/color] lb [color=#2f4f4f]">:   "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]cond [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]= bn [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]setq bn lb[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
              [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]and [b][color=BLUE]([/color][/b]snvalid bn[b][color=BLUE])[/color][/b]
                    [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] bn[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
                    [b][color=BLUE]([/color][/b]findfile [b][color=RED]([/color][/b]strcat bn [color=#2f4f4f]".DWG"[/color][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b]
               [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.INSERT"[/color] bn[b][color=GREEN])[/color][/b]
              [b][color=MAROON]([/color][/b]T [b][color=GREEN]([/color][/b]setq bn nil lb [color=#2f4f4f]""[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not ss[b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]princ [color=#2f4f4f]"\nSelect INSERTs To Update..."[/color][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b]
                              [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b]
                                  [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq i [b][color=NAVY]([/color][/b]sslength ss[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]not [b][color=MAROON]([/color][/b]minusp [b][color=GREEN]([/color][/b]setq i [b][color=BLUE]([/color][/b]1- i[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq en [b][color=MAROON]([/color][/b]ssname ss i[b][color=MAROON])[/color][/b]
              ed [b][color=MAROON]([/color][/b]entget en[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]entmod [b][color=MAROON]([/color][/b]subst [b][color=GREEN]([/color][/b]cons 2 bn[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]assoc 2 ed[b][color=GREEN])[/color][/b] ed[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
-David
  • 2 weeks later...
  • 6 years later...
Sam....
Just change the name of Lee's program to Blrep.lsp (and ind replace all brep to blrep)
it then works !!!
Lee....
is there a way to choose just the few blocks to replace ... and not all in the drawing ???
