Results 1 to 5 of 5
Thread: Polar Array
    Full Member matt4's Avatar
    matt4's Computer Details
    Windows Vista
    Samsung R20 Laptop
    Intel Core 2 Duo
    2Gb
    120Gb
    AutoCAD 2008
    Jun 2007
    London now Oxford!
    88
    Default Polar Array
    Hi,
    I am trying to polar array these circles. I need 6 equally spaced through 360 degrees. For some reason the whole array is staying in the same position as shown by the pic. Any idea what's happening?
    Sorry for all the questions
    Thanks
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    I'm guessing you should have selected the CENTRE of the larger circle to be the BASE POINT to ARRAY about?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    XP Pro (32-bit)
    Dell Precision PWS490
    Intel Xeon 5130
    4GB DDR2
    nVidea Quadro FX 3500
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2009
    Dec 2008
    Lebanon, PA
    734
    Looks like an issue with your center point. Try reselecting it (via the button to the right, cursor pointing at the red X) and make sure you locate it at the center of the larger circle you want the smaller circles arrayed around (i.e. use the center OSNAP).
    **Edit** Curses! Foiled by Strix!
    Last edited by MaxwellEdison; 6th Apr 2009 at 09:24 pm. Reason: Meddling Strix's and that mangy mutt!
    Just because you're , doesn't mean wrong is all that's .
    not applicable
    Nov 2005
    Sheffield UK
    3,074
    Quote Originally Posted by MaxwellEdison View Post
    well I don't often get to be first with the right answer on a thread
    *waits to find it's not that after all*
  5. #5
    Windows Vista
    Samsung R20 Laptop
    Intel Core 2 Duo
    2Gb
    120Gb
    AutoCAD 2008
    Jun 2007
    London now Oxford!
    88
    It worked!
    Was a issue with the centre point just needed selecting. Thanks guys!
  1. How do space the lines in polar Array?
    By andyboy in forum AutoCAD General
    Last Post: 10th Jun 2008, 04:19 pm
  2. Polar Array
    By guyzen2004 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Jun 2008, 05:34 am
  3. Polar Array going nuts...
    By Tiger in forum AutoCAD Beginners' Area
    Last Post: 29th Apr 2008, 03:11 pm
  4. Help!!! vba problem union after polar array!!!!
    By clarence_cad in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2005, 04:01 am
  5. VBA problem, union after polar array
    Last Post: 14th Oct 2005, 05:08 pm
