there was an issue between vista and autocad when vista first came out, and IIRC it was an autocad patch which set that straight rather than a windows one, so I'm not sure your problem will be resolvable as your version is so old
Hopefully I'm wrong...
check the autocad website
(BTW, it's on there, right where it should be, in C:\Program Files\Common Files\Autodesk Shared.)
best friend
