Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2009
    Feb 2009
    3
    Default Selecting underlying objects
    Hi,
    Is there a key-combo to cycle through the objects under the select box pointer? In my drawings there are often stacked objects, when I need to select one of those objects it's always the one I don't need that gets highlighted.
    Best regards,
    Geert
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Shift+Spacebar
    if you want to use just Ctrl+pick, set Legacyctrlpick=1
    Forum Newbie
    AutoCAD 2009
    Feb 2009
    3
    Thank you! That's what I was looking for. It really speeds up modifying objects.
