Lee Mac Programming
Just another Swamper
Lee Mac Programming
OK, this version includes a Replace Text/MText/Attribute Option
Just type "R" or "r" during text placement.
<code removed>
Lee Mac Programming
Lee,
When I edit an attribute it works fine until you select outside the attribute and the numbers are inserted on a slight angle.
Also please see my previous post about the zero's in the suffix unless you did spot this (I am not sure).
Thanks,
The Buzzard
Forget about the angle thing.
I see what I did wrong.
I can't seem to replicate this... if you select outside the attribute, surely it will just exit the "replace text mode" and return to just standard placement?
Yes, thank you for this suggestion, I apologise for not replying - I am just thinking of the best way to implement it.![]()
Lee Mac Programming
Lee Mac Programming
Ok, sorry for all these new versions - but just added the facility to use Leading Zeros on the incrementing text
<code removed>
Lee Mac Programming
Perfectionists have nothing to appologize for.
Lee,
This is the greatest thing since the invention of the sandwich.
Now we can all eat our words and like too.
