+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Full Member matt4's Avatar
    Computer Details
    matt4's Computer Details
    Operating System:
    Windows Vista
    Computer:
    Samsung R20 Laptop
    CPU:
    Intel Core 2 Duo
    RAM:
    2Gb
    Primary Storage:
    120Gb
    Using
    AutoCAD 2008
    Join Date
    Jun 2007
    Location
    London now Oxford!
    Posts
    88
    Default Copying/Pasting with a displacement
    Is it possible to copy/paste with a displacement in autocad 2008? Also how can you specify the direction? Such as x or y?
    Thanks!
    EDIT: Ignore found it all!
  2. #2
    Super Moderator Cad64's Avatar
    Computer Details
    Cad64's Computer Details
    Operating System:
    Windows 7 Profesional x64
    Computer:
    XI Computers
    Motherboard:
    Asus P8Z77-V Pro
    CPU:
    Intel Core I7 3770K 4.1 Ghz Quad Core 3rd Gen
    RAM:
    8GB DDR3 @ 1333MHz
    Graphics:
    Nvidia GeForce GTX 570 1280MB GDDR5
    Primary Storage:
    SATAII 500GB 7200 RPM
    Secondary Storage:
    Western Digital My Book Studio Edition II - 2TB capacity
    Monitor:
    HPf2105 21" LCD Widescreen & Cintiq 21ux
    Discipline
    Multi-disciplinary
    Cad64's Discipline Details
    Occupation
    Freelance Digital Artist
    Discipline
    Multi-disciplinary
    Details
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    Using
    3ds Max 2011
    Join Date
    Feb 2006
    Location
    Southern California
    Posts
    8,434
    Default
    Can you please tell us your solution?
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  3. #3
    Senior Member Commandobill's Avatar
    Using
    AutoCAD 2008
    Join Date
    Oct 2008
    Location
    Massachusetts
    Posts
    268
    Default
    I know you got your answer but for anyone else that is doing a search for this i can do my best to explain.
    In 2008:
    If you are copying an object in side a drawing. Use the copy command, then select an object (or multiple objects) and hit enter. The command line will now ask for a first point or displacement. If you type in coordinates like "21,32" then hit enter twice it will make a copy of the object 21 units on the x axis and 32 units on the y axis up and to the right.
    If you are copying an object into another drawing then the command you want to use is "copybase". when you type that into the command line it will ask you for a base point. The easiest point to use is "0,0". Then if you change into your new drawing and paste it will ask you for an insertion point. If you use "0,0" it will place it exactly where it is on the other drawing. but if you used "21,32" then hit enter it will place the object 21 units on the x axis and 32 units on the y axis up and to the right.
    Hope this helps.
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
  4. #4
    Full Member GCarr78's Avatar
    Discipline
    Landscape
    Using
    AutoCAD 2010
    Join Date
    Apr 2009
    Location
    Toronto, Canada
    Posts
    86
    Default
    Quote Originally Posted by Commandobill View Post
    In 2008:
    Hope this helps.
    Sometimes I cheat and with my "ORTHO" tool on I can move the object I am copying either on the "X" or "Y" axis and just enter the remaining axis distance, might save you time.
Similar Threads
  1. Fatal error on copying and pasting
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 22nd May 2008, 05:12 pm
  2. Inconsistencies in copying and pasting
    By intern in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Mar 2007, 08:25 pm
  3. Fatal error on copying and pasting
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 29th Jan 2007, 09:02 pm
  4. Delay when copying and pasting
    By Carl80 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2006, 08:44 am
  5. copying and pasting
    By BRENT in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2004, 09:35 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
