Results 1 to 5 of 5
    Junior Member
    AutoCAD 2015
    Dec 2008
    15
    Default Change lineweight via xref
    It's hard to understand what Autodesk has done with AutoCAD features:
    Am I not supposed to be able to change xref-layer's lineweight in the host's Layer Properties Manager box??
    Do I have to go into the guest file and make the desired lineweight, then reload or detach and re-attach the xref file to get the lineweight I want in the host file?
    Super Member chulse's Avatar
    chulse's Computer Details
    Windows 7
    17" wide screen laptop w/ 22" acer
    See details...
    chulse's Discipline Details
    Senior Urban Forester
    See details below.
    Tree Preservation Planning for civil design and developent
    Civil 3D 2016
    Jul 2007
    Front Royal, Virginia
    1,320
    I think we need a little more info here...
    What exactly happens when you try to change it?
    I might suspect VISRETAIN or perhaps a pen table issue....
    Cary Hulse
    Wetland Studies and Solutions
    Junior Member
    AutoCAD 2015
    Dec 2008
    15
    Thanks for replying.
    I change the lineweight of the xreferenced (guest) layer in the Layer Manager box of the current (host) file. So if the xref layer's lineweight is thin, say .25mm. I thought I should be able to change the lineweight appearance of that same externally referenced layer in the current file to .80mm. So this layer is thin in the xref (guest) file, but is showing thick in the current (host) file, which could be seen in the print preview. However, I did not achieve this; the preview showed that layer remained as .25mm. I had to go back into the xref file, make that layer .80mm, and save. Then go back to the host file and reload the xref file and checked the preview which now showed me the thick .80mm lineweight.
    Senior Member EMS_0525's Avatar
    EMS_0525's Computer Details
    XP
    HP xw8400 Workstation
    4GB
    250GB
    Dual Dell 18" flat screens
    Civil 3D 2013
    Nov 2008
    Pittsburgh PA
    253
    same thing with linetype scale or generation.... I hate xrefs......
  5. #5
    Windows 7
    See details...
    See details below.
    Civil 3D 2016
    Jul 2007
    1,320
    Quote Originally Posted by "Mitch" View Post
    Try VISRETAIN = 1
    Cary Hulse
  1. Can't change lineweight?!
    By Evil_eyes in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2012, 04:10 pm
  2. change xref color
    By astrosfan in forum AutoCAD Beginners' Area
    Last Post: 4th Jun 2009, 04:41 pm
  3. change the color/lineweight of an attribute
    By sdugan in forum AutoCAD Beginners' Area
    Last Post: 8th Dec 2008, 07:10 pm
