Make a new dim style just for your leaders?
In the dimension style there is the option to set arrow size. Usually I have this set to 100, but when using leader I want it to be 0. Can this be set somewhere so that I don't need to change it to 0 afterwards?
If at first you don't succeed - remove all evidence you ever tried.
^ X3. Normally I just create a new dimension style, starting with another dimstyle, then select "use for leaders and tolerances". Change the arrow size and save. Set the source dimstyle as current your leaders will come up with the desired arrowhead size.
"AS IS" AND WITH ALL FAULTS.
