MiGo Posted April 15, 2009 Share Posted April 15, 2009 How does one capture the imageframe setting and set something to it? (setq Iframe... I'm after turning the image frame on and then returning it to it's original number, but i'm not sure how to capture the original number. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 There are no variables for this command so you may have to do it like this: (setq IFRAME-ON (command "_.IMAGEFRAME" "ON")) (setq IFRAME-OFF (command "_.IMAGEFRAME" "OFF")) The Buzzard Quote Link to comment Share on other sites More sharing options...
MiGo Posted April 15, 2009 Author Share Posted April 15, 2009 When using imageframe the options are 0, 1, 2 so the whole on/off part won't work. On every drawing that I have dealt with the imageframe has always been set to zero, but I just wanted to try and capture that integer and set it back. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 15, 2009 Share Posted April 15, 2009 Does IMAGEHLT affect things? Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 Once again but this time from AutoCAD help section Commands IMAGEFRAME Controls whether image frames are displayed or hidden from view System Variables No entries. There are no variables unless you set to a variable yourself. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 I do not believe that is part of the same command Lee. Quote Link to comment Share on other sites More sharing options...
MiGo Posted April 15, 2009 Author Share Posted April 15, 2009 IMAGEHLT set to zero makes it so the border hightlits if on when over the image border. If set to one it makes a cross pattern over the image when selected or if hovering over border that is set at 45deg box pattern. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 15, 2009 Share Posted April 15, 2009 I do not believe that is part of the same command Lee. My mistake - sorry guys Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 Try this (defun C:IMGFRAME () (setq IFRAME (getint "\nEnter An Integer:")) (progn (if (= IFRAME 1) (command "_.IMAGEFRAME" "ON") ) (if (= IFRAME 0) (command "_.IMAGEFRAME" "OFF") ) ) ) Quote Link to comment Share on other sites More sharing options...
wizman Posted April 15, 2009 Share Posted April 15, 2009 (setq iframe (cdr (assoc 70 (dictsearch (namedobjdict) "ACAD_IMAGE_VARS")))) 0 => Imageframe set to Off 1 => Imageframe set to On 3 => Imageframe set to On but will not plot Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 Just ran it. That is something wizman! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 15, 2009 Share Posted April 15, 2009 Try this (defun C:IMGFRAME () (setq IFRAME (getint "\nEnter An Integer:")) (progn (if (= IFRAME 1) (command "_.IMAGEFRAME" "ON") ) (if (= IFRAME 0) (command "_.IMAGEFRAME" "OFF") ) ) ) Buzzard, I'd be more inclined to use COND in this instance: (defun C:IMGFRAME (/ IFRAME) (initget 5) (setq IFRAME (getint "\nEnter An Integer:")) (cond ((= IFRAME 1) (command "_.IMAGEFRAME" "ON")) ((= IFRAME 0) (command "_.IMAGEFRAME" "OFF")) (T (princ "\nNo a Valid Integer"))) (princ)) Not meaning to sounds critical - only helpful Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted April 15, 2009 Share Posted April 15, 2009 Your known to be more precise Lee. We have come to expect that. And I would not expect less. I just did that one fast off the top of my head. But thats excellent. What do you expect from a Buzzard with a bird brain. Quote Link to comment Share on other sites More sharing options...
