Scale selected lines about their midpoints
eddablin
Hi. I have a first floor plan of a large building and have drawn beams to the midpoint of columns. Its common practice to have the lines shrunk so it looks like this on plan:
I ------- I
rather than
I----------I
It would save me a lot of time if I had a piece of code that made them all scale about their midpoints rather than scale each line by its base points separately. Anyone have a solution?
Many thanks!
How much do you need them scaled by? Are they all on their own layer? Are they lines or Polylines or LWPolylines?
Hi Lee. Thanks for the response.
They are all lines. Ideally the scale could be user input. If not a scale of 0.8 would be good.
Thanks
Give this a shot:
(defun c:scl  (/ ss scl)
 (vl-load-com)
 (or scale:def (setq scale:def 0.)
 (if (setq ss (ssget "X" (list (cons 0 "LINE")
                               (cons 8 "Beams")
                               (if (getvar "CTAB")
                                 (cons 410 (getvar "CTAB"))
                                 (cons 67 (- 1 (getvar "TILEMODE")))))))
     (initget 6)
     (setq scl (getreal (strcat "\nSpecify Scale Factor <" (rtos scale:def) "> : ")))
     (or (not scl) (setq scale:def scl))
     (foreach x  (mapcar 'vlax-ename->vla-object
                         (mapcar 'cadr (ssnamex ss)))
       (vla-ScaleEntity x
         (vlax-3D-point
           (vlax-curve-getPointatDist x
             (/ (vla-get-length x) 2.0))) scale:def)))
   (princ "\n<!> No Lines Found <!>"))
 (princ))
Give this a shot:
 (vl-load-com)
                               (cons 8 "Beams")
                               (if (getvar "CTAB")
     (initget 6)
       (vla-ScaleEntity x
         (vlax-3D-point
 (princ))
Worked an absolute treat! I wish I could code these. Would save so much time. Thank you so much! Lifesaver
Hi Lee,
One more question: I would like to resize everything on the layer "columns" about its midpoint. These columns are mostly in the form of squares but i think some might have been formed by 4 lines.
I tried to edit your code but failed. They just resized about a corner.
Thanks in advance
Hi Lee,
Thanks in advance
My code was only engineered for the initial problem - it was not universal.
This will scale the squares with the basepoint at their centres.
(defun c:scl  (/ ss scl st 3p)
 (vl-load-com)
 (if (setq ss (ssget
                     (list (cons 0 "*Polyline")
                           (cons 8 "Columns")
                           (if (getvar "CTAB")
     (initget 6)
       (setq st (vlax-curve-getStartPoint x)
             3p (vlax-curve-getPointatParam x 2.0))
       (vla-scaleEntity x
         (vlax-3D-point
           (polar st (angle st 3p) (/ (distance st 3p) 2.0))) scale:def)))
 (princ))
It makes a ton of assumptions though - like them being perfectly square, etc
