auto cad 2008 32-bit
CRPPIPER
AFAIK you need a version of 64 bit Autocad.
My installation disc for Civil 3D 2008 states for 'Windows Vista (32 bit)'. Attempts at installing on a 64 bit system have failed. I don't know if this holds true for vanilla Autocad.
Your reseller should be able to supply you with the correct version.
lol.. ok.. well i tried to install it and it stoped and said i had 32-bit autocad that doesnt work on 64-bit system... ill just have to keep using my autocad on the old computer! the new computer is a nice touch screen 22" HP was looking forward to it! no worries
Did you contact your reseller? Are you on subscription? Did you try contacting Autodesk?
If you have a DVD it should have both the 32-bit and the 64-bit version of AutoCAD 2008 on it. Mine does. However, if you have a CD there is not enough room on it to store both versions therefore you have to request the version you are missing from your authorized reseller or contact AutoDesk directly.
  • 2 months later...
