Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2009
    Apr 2009
    5
    Default Creating Paper Space A1, A2, A3, A4
    Hi,
    I've been using CAD 2009 recently and up until now I've never had to create a new Paper Space layouts from scratch. At work I've always used pre-saved templates with title blocks already added.
    I would like to create new Paper Space tabs and set up A1, A2, A3 and A4 layouts so that I can add my new title blocks, layers, line weights etc.
    When I click MENU BROWSER - FILE - NEW the only options I get are the pre-saved templates, which I don't want to use. Do I use the Page Setup Manager to create new layouts?
    Many thanks in advance,
    Sarah B
    Senior Member cpriedel's Avatar
    AutoCAD 2010
    Sep 2007
    From Germany to Seattle
    155
    If you rightclick on ur Model-tab u should see "new Layout" clck that than import your new Titleblock and use the "Page Setup Manager" to have the Layout Match your Titleblock. YOu can also rename ur Tab by righ-clicking on it and select "Rename".
    Hope that helped. Let us know
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Quote Originally Posted by Sarah B View Post
    Hi,
    Sarah B
    I would change your Startup type. type STARTUP at the command line and set it to 1. Then go to the Files tab in Options, and set the default templates path to whatever directory holds your custom templates.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Forum Newbie
    AutoCAD 2009
    Apr 2009
    5
    Thanks for that, but how do I know if my Paper Space is A4 or A3? How can I size the paper space eg A4 - 210mm x 297mm
    Many thanks
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Many thanks
    Make your changes to the page size by typing PAGESETUP and selecting the Modify button. Once you have everything complete, do a Save As and save the file as a Template (which is a *.DWT file).
  6. #6
    Forum Newbie
    AutoCAD 2009
    Apr 2009
    5
    That's brilliant, thanks for your help. x
  1. Bring Paper Space object through Viewport into Model Space
    By karenreeves in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Nov 2011, 08:58 pm
  2. LTSCALE - Model Space/Paper Space Differences and problems
    By Fedge in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2011, 02:33 pm
  3. AcadPViewport2 - Deleting items in model space that aren't seen inside paper space
    By lovemy65stang in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Aug 2009, 05:26 am
  4. Replies: 0
    Last Post: 22nd Jan 2007, 10:20 pm
  5. Creating standard drawings in Paper Space in AutoCad2006
    By briane in forum AutoCAD Beginners' Area
    Last Post: 11th Aug 2006, 09:47 pm
