john2009 Posted April 17, 2009 Share Posted April 17, 2009 Hi everyone, In AutoCAD Mechanical 2007 I'm having a problem with colors. When I change the color of a 3D solid model part within an assembly, save the drawing, then open the drawing again, the part seems to revert back to previous colors that were used during the design process. Sometimes, a part is even more than one color, one surface may be blue, another surface may be red, etc.. It seems AutoCAD is *remembering* all the colors that I tried or used throughout the design process and is somehow getting confused as to which color was the last saved color. The drawing has a fair number of layers and I wonder if the issue is somehow related to layers. If I type the layer command and change the color for the part there, and then go to "object properties" and choose "by layer" as the part color, it does not help. Additionally, if I actually choose for example *red* from object properties, I still have the problem. I can change colors fine while the drawing is open, but when I save the drawing and reopen it later, some parts are either not the color that was last saved, or some parts have several surfaces with different colors (colors that were used or tried throughout the design process). It may be worth noting that when the drawing opens, for the first few seconds the colors seem correct, then a few seconds later, the colors of certain parts within the assembly will change. When you add or subtract to or from a solid model part, does the portion that is being added or subtracted have to be on the same layer and/or be the same color as the part that is being modified ? I never had to worry about this with previous versions of AutoCAD but perhaps something changed. I would appreciate any ideas or suggestions anyone may have. Thanks John Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 18, 2009 Share Posted April 18, 2009 Since this question hasn't received any responses, I've moved it to the "Mechanical" section. Quote Link to comment Share on other sites More sharing options...
john2009 Posted April 18, 2009 Author Share Posted April 18, 2009 Thanks CAD64, when I originally posted I did not even see the "mechanical" section under "AutoCAD vertical products". John Quote Link to comment Share on other sites More sharing options...
kakody1 Posted April 25, 2009 Share Posted April 25, 2009 When i had autocad mechanical 2007 i had faced a lot of problems so i changed to autocad 2008 and then 2009. Many times it was crashing when i was working. Quote Link to comment Share on other sites More sharing options...
