Dimension size
onntkkk
AutoCAD version: 2008 LT
Hi, I am a newbie in autocad. May be it a very simple question but I am really struggle in it and don’t know what to do next. Please help.
Below is my problem.
1) When a block explode in my model, the dimension size change to very small.
2) All my dimlinear also very small but the dimdiameter look fine.
Thank you in advance for your help.
Select One Of The Dimension & Check In Property, Which Style Is Used. Than Open Dimension Style Dialoguebox, Slect That Style & Click Edit & Than Edit The Text Height In There So It Will Update All Dimensions Text Height. If It Does Not Update Automatically, Type At Command Line - 'dim' Enter 'upd' Enter 'all' Enter
