How to tell Start Point of a Spline
Proctor
Hello:
when I use the list command to get properties of my spline, i see 4 control points listed(see output below):
when debugging, i would think that the start point would be equivalent to either the geometric max or min point therefore it should
be either X = 177.5898 , Y = 52.1529 , Z = 0.0000
or
X = 185.3957 , Y = 51.9440 , Z = 0.0000
but according to my code, it's saying that the start points is:
X = 180.1918 , Y = 52.0833 , Z = 0.0000
and I'm having a hard time understanding how this could be the start point?
thanks for your help,
Proctor
Select objects: 1 found
Select objects:
SPLINE Layer: "2 PER FT LT"
Space: Model space
Handle = 104d
Length: 7.8087
Order: 4
Properties: Planar, Non-Rational, Non-Periodic
Parametric Range: Start 0.0000
End 7.8087
Number of control points: 4
Control Points: X = 185.3957 , Y = 51.9440 , Z = 0.0000
X = 182.7937 , Y = 52.0136 , Z = 0.0000
Number of fit points: 2
User Data: Fit Points
Fit point tolerance: 1.0000E-10
Draw a spline with the first point at 0,0,0. Then list it, the first control point (start of the spline) will be listed as 0,0,0
You can test it with this
(defun c:test ()
 (setq obj (vlax-ename->vla-object (car(entsel))))
 (vlax-curve-getStartPoint obj)
Hello lpseifert: thank you for your help.
My apologies that I didn't indicate I'm coding in .net api.
I drew a few splines as suggested and when i did list on these,
it always lists the start point first. would you agree that this is what it does? does it list the start point first and the end point last?
perhaps getting the start point in .net api is different than for other objects so I will check that out.
thanks again for taking the time to reply.
Proctor
