Results 1 to 10 of 10
    Full Member matt4's Avatar
    matt4's Computer Details
    Windows Vista
    Samsung R20 Laptop
    Intel Core 2 Duo
    2Gb
    120Gb
    AutoCAD 2008
    Jun 2007
    London now Oxford!
    88
    Default Draw twice full size but keep full size dimensions
    Hi,
    I have drawn a component twice full size. However when I start dimensioning it takes the dimensions done at twice full size.
    For e.g component is 80mm long twice full size, dims show up as 80mm long but I need it at 40mm. Can't use text override for this.
    Thanks
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by matt4 View Post
    Hi,
    Thanks
    Please consider drawing everything to its true size, then in a layout you can make a viewport and zoom to 2xp to accomplish the same thing. Dim in layout.
    I don't want to explain how to manipulate the dimstyle to reduce the dims by half as this leads to drawing things out of true size.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Select the dimension, in Properties you can change 'Dim scale linear' to be 0.5
    me bad... listen to rkent
    Last edited by lpseifert; 17th Apr 2009 at 08:47 pm. Reason: Bailiff... whap his peepee
    Full Member Came's Avatar
    Came's Computer Details
    xp
    1 gb
    radeon 550x
    320 gb
    samsung 17
    AutoCAD 2008
    Feb 2009
    76
    Hi,
    Thanks
    Draw everything in full size then in paper space, you do dimension at 2x
    Ipseifert: didn't thought of that
    am learning basic , that's what you think
  5. #5
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Quote Originally Posted by lpseifert View Post
    Select the dimension, in Properties you can change 'Dim scale linear' to be 0.5.
    Works fine however do listen to rkent.
    Myself, too old to know better, work only in model space so,
    I use would use the 'Dim scale linear' to accomplish the mission.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  6. #6
    Windows Vista
    Samsung R20 Laptop
    Intel Core 2 Duo
    2Gb
    120Gb
    AutoCAD 2008
    Jun 2007
    London now Oxford!
    88
    Thanks all, I think this method above is the best for me. However when I change to 0.5 it only changes the size of the dim line. Not the dimensions itself.
  7. #7
    xp
    1 gb
    radeon 550x
    320 gb
    samsung 17
    AutoCAD 2008
    Feb 2009
    76
    Yes, it doesn't change dimensions.
  8. #8
    Windows Vista
    Samsung R20 Laptop
    Intel Core 2 Duo
    2Gb
    120Gb
    AutoCAD 2008
    Jun 2007
    London now Oxford!
    88
    Ah, Got it now.
    Thanks
  9. #9
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Since you are strictly using MS then reduce your title block by 1/2 and the model remains true size. No mucking about with dim settings. Then adjust the dim scale to double what you would normally use.
  10. #10
    Super Member skipsophrenic's Avatar
    skipsophrenic's Computer Details
    Vista 32 bit
    Compaq
    erm . . yeah?
    Intel Pentium Dual CPU E2140 @ 1.60 Ghz
    2039MB
    don't ask you'll kill me
    360gb
    21" widescren - 16:10 ratio
    AutoCAD 2008
    Jul 2008
    Birmingham, United Kingdom
    1,020
    Why don't u select the component and scale it down to 0.5 it's original size, that way
    you'll have a true size component and wont need to worry about changing the
    dimensions,
    Quick tip for you, it's good practice to ALWAYS draw what u want in modelspace at
    "Normail Size" that way you avoid further complications down the road.
    Just my thought for a penny.
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
    SET FILEDIA = 1
  1. Full screen?
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 13th Sep 2011, 04:45 pm
  2. create and plot full size pdf properly
    By cadfly in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jan 2008, 07:48 pm
  3. not using cad to full potential
    By legend in forum AutoCAD Beginners' Area
    Last Post: 26th Nov 2007, 10:16 pm
  4. How to draw Rectangle: Center-Full Base-Full Height?
    By LihtiumOverdosE in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Oct 2005, 07:00 pm
  5. Plot size on server is much larger than drawing size
    By chewy-d in forum AutoCAD Drawing Management & Output
    Last Post: 1st Nov 2003, 03:25 pm
