matt4 Posted April 17, 2009 Share Posted April 17, 2009 Hi, I have drawn a component twice full size. However when I start dimensioning it takes the dimensions done at twice full size. For e.g component is 80mm long twice full size, dims show up as 80mm long but I need it at 40mm. Can't use text override for this. Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted April 17, 2009 Share Posted April 17, 2009 Hi, I have drawn a component twice full size. However when I start dimensioning it takes the dimensions done at twice full size. For e.g component is 80mm long twice full size, dims show up as 80mm long but I need it at 40mm. Can't use text override for this. Thanks Please consider drawing everything to its true size, then in a layout you can make a viewport and zoom to 2xp to accomplish the same thing. Dim in layout. I don't want to explain how to manipulate the dimstyle to reduce the dims by half as this leads to drawing things out of true size. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted April 17, 2009 Share Posted April 17, 2009 Select the dimension, in Properties you can change 'Dim scale linear' to be 0.5 me bad... listen to rkent Quote Link to comment Share on other sites More sharing options...
Came Posted April 17, 2009 Share Posted April 17, 2009 Hi, I have drawn a component twice full size. However when I start dimensioning it takes the dimensions done at twice full size. For e.g component is 80mm long twice full size, dims show up as 80mm long but I need it at 40mm. Can't use text override for this. Thanks Draw everything in full size then in paper space, you do dimension at 2x Ipseifert: didn't thought of that Quote Link to comment Share on other sites More sharing options...
Tankman Posted April 17, 2009 Share Posted April 17, 2009 Select the dimension, in Properties you can change 'Dim scale linear' to be 0.5. Works fine however do listen to rkent. Myself, too old to know better, work only in model space so, I use would use the 'Dim scale linear' to accomplish the mission. Quote Link to comment Share on other sites More sharing options...
matt4 Posted April 17, 2009 Author Share Posted April 17, 2009 Select the dimension, in Properties you can change 'Dim scale linear' to be 0.5 me bad... listen to rkent Thanks all, I think this method above is the best for me. However when I change to 0.5 it only changes the size of the dim line. Not the dimensions itself. Quote Link to comment Share on other sites More sharing options...
Came Posted April 17, 2009 Share Posted April 17, 2009 Yes, it doesn't change dimensions. Quote Link to comment Share on other sites More sharing options...
matt4 Posted April 17, 2009 Author Share Posted April 17, 2009 Ah, Got it now. Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted April 18, 2009 Share Posted April 18, 2009 Thanks all, I think this method above is the best for me. However when I change to 0.5 it only changes the size of the dim line. Not the dimensions itself. Since you are strictly using MS then reduce your title block by 1/2 and the model remains true size. No mucking about with dim settings. Then adjust the dim scale to double what you would normally use. Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted April 19, 2009 Share Posted April 19, 2009 Why don't u select the component and scale it down to 0.5 it's original size, that way you'll have a true size component and wont need to worry about changing the dimensions, Quick tip for you, it's good practice to ALWAYS draw what u want in modelspace at "Normail Size" that way you avoid further complications down the road. Just my thought for a penny. Quote Link to comment Share on other sites More sharing options...
