are you going to be running Vista 64 or XP 64? The most physical memory that a 32 bit OS can see is 4gb. If you are going to be doing a ton of 3d modeling that has complex forms, or tons of rendering I should suggest more than 2, but otherwise I would stick to the recommendations with the system specs.
