Quick and dirty:
Draw your path using the POLYLINE command.
Draw a circle representing your pipe.
Rotate the circle so that it's perpendicular to one end of the path using the 3dROTATE command.
EXTRUDE the circle along the PATH.
Hi All,
I'm used to a few other packages but am currently working on a 3D AutoCAD project.
I can't seem to create a rod with a bend in it in solid or surfaces, with the systems I'm more familiar with you create a path and select it as a pipe routing giving the radius at each end. I can use the cylinder command to create straight rods, however i need to create a few with a number of bends in.
Any suggestions would be gratefully received.
Quick and dirty:
AutoCAD 2005
ADT 2005
Thanks very much, thats sorted my needs so far, however if that's the quick n dirty, is ther a long n clean?
I'll see what I can do for you at lunch...I'm finishing up a menu system for a client right now...want to finish before the weekend...
AutoCAD 2005
ADT 2005
