Entmake Hatch
Lee Mac
  • Replies 38
  • The Buzzard
    22
  • Lee Mac
    14
  • wizman
    3
Popular Days
entmakex Function
Makes a new object or entity, gives it a handle and entity name (but does not assign an owner), and then returns the new entity name.
I never new this existed.
Lee,
I went back to earlier posts and did not see the EN.lsp.
Thats real cool. I just tested it on a block and it broke down everything.
I will get alot of use out of that code for sure.
Thanks Again.
No Probs, and thanks Wizman for that tip. I was aware of the entmakex function, but didn't know that you could just leave in the entity name and handle etc when providing it with arguments... good to know :thumbsup:
Lee
Wiz,
Out of curiosity, What are the main benefits between the two?
Other than leaving in the entity name and handle.
I can see that, But I would think there would be more to it to have two command function that basically do the same thing, But one does just a bit more. Does not seem to make that much sense to me. Why not just have one.
Lee,
What is meant by the following:
Warning! Objects and entities without owners are not written out to DWG or DXF files. Be sure to set an owner at some point after using entmakex. For example, you can use dictadd to set a dictionary to own an object.
Found this at the bottom of the page for entmakex function.
entmakex is fine with graphical entities and table entries and need to worry about the warning when dealing with dictionary. For example are groups and xrecords, you need entmakex to create the non graphical entities, but needs an extra append function in the dictionary or else it will be lost once the drawing has been closed.
Some good posts, But still some questions partially unanswered.
The only way to know for sure is try it and see what happens.
I will setup some test blocks and find out.
For Eg:
http://www.cadtutor.net/forum/showpost.php?p=212432&postcount=2
