Results 1 to 4 of 4
    Super Member gcp310's Avatar
    not applicable
    Dec 2002
    physicaly - Australia, mentaly - Another Planet
    696
    Default wow, first SU post for me
    ok, i have had a play around this morning with SU and have come up with a little image. i have to set up the standard framelock beams and posts as "components" and have started to do so.
    this is what i have so far.
    how can i get rid of or reduce the segmenting of curved items??
    thanks
    G
    Senior Member boofredlay's Avatar
    AutoCAD 2007
    Apr 2005
    Huntsville, Alabama
    274
    Nice start. To get a smoother circle (arc) you need to set the segments prior to drawing the circle.
    Actually you can change it after drawing the circle but once you have push/pulled you cannot.
    So it is a good rule of thumb to always set your segments first.
    When you click on the circle tool (or arc) you will see a number in the VCB (Value Control Box).
    Just type the number you want (don't click in the VCB window).
    Eric Lay
    Visit my Blog - View my Portfolio - Revit - SketchUp - Autocad - Photoshop - Twilight Render - Thea Render
    not applicable
    Dec 2002
    696
    ahhh, nice, thanks for that.
    not applicable
    Dec 2002
    696
    works a treat.
    awesome.
  1. Come on POST !!!
    By Mr T in forum Autodesk Inventor
    Last Post: 19th Nov 2004, 05:39 pm
