matt4 Posted April 22, 2009 Share Posted April 22, 2009 Hi, Can hatched areas such as this be trimmed/erased? Tried it and am getting no where. Re-hatching doesnt work as I still get a hatched line going through the main component. Thanks Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted April 22, 2009 Share Posted April 22, 2009 should be able to, i do it every day at work. Quote Link to comment Share on other sites More sharing options...
James Burke Posted April 22, 2009 Share Posted April 22, 2009 When trimming, do it the long way. Click on the trim boundry, hit enter and then trim the hatched areas. The trim short cut (tr, enter, enter) does not seem to work with hatched areas. Jim Quote Link to comment Share on other sites More sharing options...
Zorba Posted April 22, 2009 Share Posted April 22, 2009 I have same problems, and it depends on what version of CAD you use and/or drawing. I get the error "Cannot trim this area", but i used to do it all the time. Think the word 'bug' springs to mind. Quote Link to comment Share on other sites More sharing options...
matt4 Posted April 22, 2009 Author Share Posted April 22, 2009 Manage to remove it. Thanks all Zorba, I used to be able to do it in Autocad 2005 must be a bug indeed Quote Link to comment Share on other sites More sharing options...
James Burke Posted April 22, 2009 Share Posted April 22, 2009 We're running '07, and it seems to do okay. It looks as though all your boundaries are closed, but did you double check to see if there's a small gap somewhere? I like to do a corner radius of zero and hit all the intersections whenever something like that happens. I've tinkered with multiple layers and it still trims regardless of which layer is current. Jim Quote Link to comment Share on other sites More sharing options...
