Results 1 to 2 of 2
    Junior Member
    AutoCAD 2007
    Feb 2009
    10
    Default "Rotated" dimension doesn't edit
    My linear dimension properties have somehow changed into "rotated" dimensions...whatever those are. I can not change text height through the dimstyle or through individual dimension properties....what's up with that?
    Many thanks,
    Jim
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    Windows 7 Professional
    Dell
    Intel Xeon E5-1603@2,80GHz
    4GB
    NVIDA Quadro K600
    DELL 23" & SAMSUNG 21"
    not applicable
    Nov 2005
    Kenley, Surrey, UK
    5,644
    ALL dimensions are "Rotated Dimension", it is the class of object. The only reason I can think that a text height can't be changed is if its STYLE is a set height rather than 0.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    "Everything in drafting is logical. Except what isn’t." - Gavin Guile. (from the Lightbringer series of books by Brent Weeks)
    Dave
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  2. Dimension "style overrides"
    By bbfirebird in forum AutoCAD Drawing Management & Output
    Last Post: 11th Jan 2012, 04:40 pm
  3. Edit "Space Generate" Tool
    By caddie in forum Architecture & ADT
    Last Post: 18th Mar 2009, 09:58 pm
  4. A "copy then edit" command?
    By closedflat in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jan 2008, 12:13 am
  5. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
