Results 1 to 5 of 5
    Forum Newbie
    Inventor 2008
    Apr 2009
    2
    Default how to model a piece
    Hello all. I need to model this piece, and I don't know how to make the serrated face. Is there any way of doing it in an automated way? Or I should draw one tooth and make a circular pattern? (I tried this, but the piece is so small that I cannot measure it properly).
    Any suggestion? Thanks!
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    3,249
    this may be a silly question, but if you can measure it accurately how do you plan to draw it accurately? Are you just drawing this for fun?(not production).
    if you look at the part, the outter edge of your ratcheting teeth have a wider peak than the inner edges. I would draw your cylinder, then draw a triangle in the center of your circle, extrude(cut) it out from the center then do a circular pattern. I havent seen anything like that in the content center but then again ive never looked for it
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks17,Mastercam2017, fusion360, Inventor 2017, HSMworksUltimate
    http://www.solidbox.tv Free and Paid Tutorials for Solidworks, Mastercam and Fusion360
    http://www.mysolidbox.com/ CAD and CAM optimized workstations and laptops
    Forum Newbie
    Inventor 2008
    Apr 2009
    2
    hehe, that's fine. I'm quite newbie in production stuff. I really am an architect, and we're not very used to measure millimiters decimes, so I pretended Inventor do it for me. :-P
    But I haven't realized that there's a triangular prism cutted from this piece! (how many things I have to learn!?)
    Thanks a lot!
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Give it a try and then attach what you have so far. Or were you looking for someone to do it for you?
  5. #5
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 10
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    2TB
    Portable TB drive
    Samsung SyncMaster 226
    Mechanical
    Lazer's Discipline Details
    Design Engineering Manager
    Mechanical
    Mechanical Designer using Autocad and Inventor
    Inventor 2018
    Aug 2005
    Northants, England
    1,819
    You don't have to measure all the teeth, just the pitch between 2 will do, then use the array command, that's a very easy model to do, post what you have done so far so we can help
    USING AUTOCAD 2016 AND INVENTOR 2016, ALIAS 2016 SHOWCASE 2016.
    If in doubt scale and don't ask!
  1. Doubling the size of an incorrectly drawn piece
    By JamesH81 in forum AutoCAD General
    Last Post: 15th Oct 2008, 01:07 pm
  2. Replies: 7
    Last Post: 5th Feb 2008, 08:37 am
  3. Transition Piece patterns
    By engineer1 in forum Autodesk Inventor
    Last Post: 2nd May 2006, 02:17 pm
  4. HVAC transition piece
    By engineer1 in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2006, 09:34 pm
  5. Colours of the 'model' in model explorer
    By Vj in forum AutoCAD General
    Last Post: 21st Nov 2005, 05:20 pm
