Results 1 to 4 of 4
    Junior Member rajeshjm's Avatar
    rajeshjm's Computer Details
    Windos Xp
    Mechanical 2009
    Jul 2008
    India
    12
    Default Range Validate in VBA
    In my VBA code based on user input it has to execute the statement
    I need a code for this statement
    i created two text box. one for input and other for output
    If the input value is between 1 to 10 (it means the value may be 1 or 2 or 3 or 4 etc.....) then it need to show "A" in output
    similarly If the input value is between 11 to 20 then it need to show "B" in output
    Senior Member CmdrDuh's Avatar
    CmdrDuh's Computer Details
    HP workstation xw8200
    2gig, soon to be 4
    Dual 21s
    AutoCAD 2009
    May 2008
    AZ, USA
    396
    the simple way to do this is to restrict the textbox keypress to 0-9 only, then after pressed, read the value. THe problem you are going to have is if the user intends to press 12, when the 1 is pressed, textbox2 will display A, then when the 2 is pressed, it will change to B. What do you have so far?
    Everyone has a Photographic memory, some just don't have film
    Senior Member bsamc2000's Avatar
    bsamc2000's Computer Details
    Windows 7
    HP Z400
    Intel Xeon 2.66GHz
    NVIDIA GeForce 9500 GT
    E228WFP (2x)
    AutoCAD 2011
    Mar 2007
    Columbus, Ohio
    120
    I have wrote a couple of programs that do this in VB .Net using "Regular Expressions". Do a quick Google search to see how to use them. You should be able to test for a wide variety of conditions. I use this alot to convert between units of measure.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Couldn't you use a if ?
    If > 0.5 and < 10.5 then do one
    If > 10.6 and < 20.5 then do two
    If lots of numbers use case, if only two < 10.5 or > 10.5
  1. how do I constrain two faces to a range of motion?
    By geoffrey in forum Autodesk Inventor
    Last Post: 3rd Apr 2009, 04:32 pm
  2. Join-connect a range of points.
    By therock005 in forum AutoCAD General
    Last Post: 3rd Feb 2009, 05:26 am
  3. To define a range in the code
    By Hmm.. in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Aug 2008, 09:08 am
  4. range of commands Help
    By BAD_WOLF in forum AutoCAD Beginners' Area
    Last Post: 3rd Jun 2006, 06:12 am
