how can I turn off one layer in many dwgs?
CadTechJGC184
ahhhhhhhhhhhhhh why can"t I added a print screen.... i give up!!
here's the xref name and layer: UTILITY BASE/C-ELEC-LIN
Open all the docs you need to freeze the layer in and use this:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] frzlay [b][color=RED]([/color][/b]lay [b][color=BLUE]/[/color][/b] doc lyr[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-for[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Documents[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lyr [b][color=RED]([/color][/b][b][color=BLUE]vla-item[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-layers[/color][/b] doc[b][color=RED])[/color][/b] lay[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
        [b][color=RED]([/color][/b][b][color=BLUE]vla-put-freeze[/color][/b] lyr [b][color=Blue]:vlax-true[/color][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Just hit the print screen button, paste into MS Paint, and save as JPEG, then attach.
hey Lee Mac,
How are you doing? thanks for the suggestions. i will give them both a try.
Open them all at once.
I have just tested it though, and its seems to have a problem if the layer to be frozen is not in the drawing - which is weird because I thought I had accounted for that :huh:
Are you calling the function correctly?
It is a sub-function and should be called as follows:
[/color][/b][color=RED][color=Black](frzlay[/color][/color][b][color=RED][color=Black] "[/color][/color][/b]UTILITY BASE/C-ELEC-LIN")
what do i type once I have opened all the drawing that i want the layer frz in? Is it a lisp?
You can make your own LISP to call the sub-function and call it what you like:
[/color][/b][color=RED][color=Black](defun c:whatever ()[/color]
[/color][color=RED][color=Black]  (frzlay[/color][/color][b][color=RED][color=Black] "[/color][/color][/b]UTILITY BASE/C-ELEC-LIN")
 (princ))
(defun c:frzlay (lay / doc lyr)
(vlax-for doc (vla-get-Documents
(vlax-get-acad-object))
(and (setq lyr (vla-item (vla-get-layers doc) lay))
(vla-put-freeze lyr :vlax-true)))
(princ))
(frzlay "UTILITY BASE/C-ELEC-LIN")
(princ))
is this correct? I'm a little lost.
The frzlay is a sub-function (no "c:"), and needs to be called with one argument (the layer string), from a main-function (which can be named whatever you like - but not the same as the sub-function).
When you save LISPs, the filename can be whatever you like - it doesn't have to be the syntax name.
I have been in conversation with RonJonp and he has provided a better way to cope with layers that aren't present:
(defun frzlay  (lay / doc lyr)
 (vlax-for doc  (vla-get-documents
   (and (not (vl-catch-all-error-p
               (setq lyr (vl-catch-all-apply 'vla-item
                           (list (vla-get-layers doc) lay)))))
 (princ))
(defun c:test ()
 (princ))
Save as filename.lsp, open all drawings and invoke with "test"
i opened 3 just for a test and I typed frzlay, because that's what I named it c:frzlay not c:test and the layer was still thawed.
Also, don't name it the same name as the sub-function :geek:
