Results 1 to 4 of 4
    Full Member
    AutoCAD 2009
    Apr 2009
    41
    Default Layering arrangement
    Hi,
    I have a small problem on layering system is there any body know how to arrange or one of the layer will set in the first on the table, For exampe i want the layer DEFPOINTS will be the first in the table
    because some cases when the defpoints is off i want to turn it on its hard to search on it when there to many layers are set on the drawings including the xref files so i'm shearching that how will the defpoint to be on the first on the table, or rather i can arrange it what i want by my own sets of layers?
    Senior Member JoeC's Avatar
    AutoCAD LT 2011
    Aug 2008
    Georgia, USA
    180
    Could you rename layer Defpoints to Adefpoints or whatever to make it first alphabetically?
    Senior Member
    AutoCAD 2004
    Apr 2006
    235
    You can't change 'Defpoints' itself, but yeah, you can create a pseudo-Defpoints layer and have it named something higher up on the list. But this then could be an issue with your office's standards, especially if you're sending these drawings out to other companies that may not catch on that there's a different 'Defpoints' layer being used.
    I'd just start practicing
    -la*
    on*/off*
    defpoints*
    Justin J. F. RamireZ - Drafter Extraordinaire
    Bryan/College Station, Tx
    REVIT MEP 2009, CAD MEP 2009, CAD LT '00 & '04, CAD 04
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    just hit the "DE" key when you drop down the Layer menu. And a side note, its not good to use the Defpoints layer ever. Its good practice to have a no plot layer (usually set up as A-NPLT for the layer name).
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. Uniclass layering
    By jonesy in forum Catch All
    Last Post: 16th Jul 2010, 01:56 pm
  2. Dimension layering
    By phall in forum AutoCAD General
    Last Post: 18th Jul 2008, 08:26 am
  3. quick layering
    By fbby in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st May 2008, 09:20 am
  4. Layering Issue
    By newtoautocad in forum AutoCAD General
    Last Post: 26th Jul 2007, 02:20 pm
  5. Layering Problems
    By JamesTruro in forum AutoCAD Drawing Management & Output
    Last Post: 13th Mar 2007, 07:10 pm
