Results 1 to 8 of 8
    Full Member
    AutoCAD 2004
    Oct 2007
    74
    Default Search and replace inside string variable?
    Dos anyone know if it is possible to run a find and replace within a string variable?
    I have a string variable that holds a string that concantenates a room name, letter and material: Example: Master Bath--A--Eos Acadia.
    I am able to remove the spaces from the variable via the "trim" function:
    (setq PRINT_CNC_TEXT(trim PRINT_CNC_TEXT "BMA" ))
    What I would also like to do is replace the two dashes with a single dash. I tried the following but it didn't work:
    (subst '"--" '"-" '("PRINT_CNC_TEXT"))
    Is there a way to do this inside the variable as opposed to running a search and replace inside the drawing?
    Thank you.
    AJS
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    Try running this on your drawing:
    Code:
    (defun c:repDash  (/ ss tStr pos)
      (vl-load-com)
      (if (setq ss (ssget "X"
                          (list (cons 0 "TEXT,MTEXT")
                                (cons 1 "*--*")
                                (if (getvar "CTAB")
                                  (cons 410 (getvar "CTAB"))
                                  (cons 67 (- 1 (getvar "TILEMODE")))))))
        (foreach x  (mapcar 'vlax-ename->vla-object
                      (mapcar 'cadr
                        (ssnamex ss)))
          (setq tStr (vla-get-TextString x))
          (while (setq pos (vl-string-search "--" tStr))
            (setq tStr (strcat
                         (substr tStr 1 pos) (chr 45)
                           (substr tStr (+ pos 3)))))
          (vla-put-TextString x tStr))
        (princ "\n<!> No Text Found <!>"))
      (princ))
    Lee Mac Programming
    Just another Swamper
    Senior Member
    Map 3D 2008
    Apr 2009
    The one after 909
    402
    (if (getvar "CTAB") ... shouldn't that always return true? Is there any way for "CTAB" to be nil?
    Also, couldn't you use (vl-string-subst) instead of (strcat)?
    Sorry if I'm asking too many questions, I only just started getting into VLA like.. last week.. it's very new to me and I'm learning a lot, and quickly.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    Great idea about using vl-string-subst, with so many VL functions, you sometimes forget a few
    Code:
    (defun c:repDash  (/ ss tStr)
      (vl-load-com)
                                (cons 1 "*--*")
                                (if (getvar "CTAB")
                      (mapcar 'cadr
                        (ssnamex ss)))
          (while (vl-string-search "--" tStr)
            (setq tStr (vl-string-subst "-" "--" tStr)))
      (princ))
    As for the CTAB, R14 didn't have it.
    Lee Mac Programming
  5. #5
    Senior Member
    Map 3D 2008
    Apr 2009
    The one after 909
    402
    Ah, I see I see.. wow, that's a job itself, trying to make it all backwards compatible. I never did use R14.. just how different is it from, say, 2004, or 2008? I'd imagine it must at least have VL, but that it wouldn't have "ctab"...
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    Quote Originally Posted by Freerefill View Post
    Good point, I suppose the IF statement isn't required here as R14 didn't have VL either - I just keep the ssget code as a set block of code and copy it when I need it... need to look over it more in the future.
    Lee Mac Programming
  7. #7
    Full Member
    AutoCAD 2004
    Oct 2007
    74
    Thank you very much!
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    No probs, happy to help
    Lee Mac Programming
  1. Is it Possible to search for the text inside a Dwg file??...
    By sarabrajkumar in forum CAD Management
    Last Post: 24th Dec 2008, 12:31 pm
  2. Autodesk Visual Search and Content Search available on Autodesk Labs
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 23rd Oct 2007, 08:30 pm
  3. Search and Replace Attribute Values
    By Lynn Allen's Blog in forum AutoCAD RSS Feeds
    Last Post: 10th May 2007, 07:50 pm
  4. Determining if I have string characters in text a variable
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Feb 2007, 09:55 pm
  5. string text
    By brassworks in forum AutoCAD Drawing Management & Output
    Last Post: 6th Oct 2006, 03:04 pm
