Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Scaling objects
    Full Member
    Map 3D 2008
    Mar 2008
    49
    Default Scaling objects
    Hello friends,
    I tried to find answer on this before, but i didn't receive any useful solution. Let's try here...
    I draw my drawings in scale of 1:1. When I want to plot it, I choose the scale factor in plot dialog and everything is ok... I get smaller or bigger drawing plotted on paper, depending on chosen scale. But some elements in drawing (little crosses, topographic signs for tries, traffic, manholes... etc) should be plotted always in the same size no matter what scale factor I choose while plotting. It takes so much time to manually change the size of every topographic sign when client wants to have the drawings plotted in different scales.
    Putting all those topographic signs in certaing layers and scaling all together is not good solution since insertion points are different...
    I am driveing AutoCad Civil 3D now.
    Thanks for any help,
    Bane
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,556
    Look into Annotative blocks/text
    R.K. McSwain
    CAD Panacea | twitter
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    If these items are inserted in your drawing as blocks, then you have to make the blocks annotative. This means when you plot your drawing at different scales the blocks will stay the same size. You can control the scale of the objects display in your viewport properties. Unfortunately I do not have more time to explain this to you. But do a search for Annotative blocks and you will surely find more detailed explainations.
    Full Member
    Map 3D 2008
    Mar 2008
    49
    Ok, I understand... I can make annotative text, block, attributes, dimensions...
    I made a simple block using "wblock" command. After insertion to drawing I could not find a way to make it annotative.
    When I create block with "block" command there is an option to set it annotative. I chose annotative scale 1:1. Near that block I draw the same size sign which is not annotative, and tried to plot all in 4:1 plot scale. Both are plotted with the same size... Where I go wrong?
  5. #5
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Attdef my friend. Look into this. Command for Attribute Definition.
  6. #6
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,556
    Quote Originally Posted by The Buzzard View Post
    What does that have to do with the annotative blocks?
    R.K. McSwain
  7. #7
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    I was under the impression text was to be added to a block. Is that not what annotation is?
  8. #8
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,556
    What is "impression text"?
    The OP wants his/her blocks to plot the same size no matter what the viewport scale is set to. You can do this with Annotative Blocks. This has nothing to do with attributes.
    http://lynn.blogs.com/lynn_allens_bl...utocad_20.html
    http://www.thecadgeek.com/blog/2007/...ks-annotative/
    R.K. McSwain
  9. #9
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Professional 64 bit
    HP EliteBook 8570w
    Intel Core i7-3720QM 2.60GHz
    16GB
    NVIDIA Quadro K2000M
    HP
    Civil
    Tiger's Discipline Details
    Education /support
    Civil
    Support/Education/Retail
    Civil 3D 2016
    Nov 2006
    FjÀrdhundra, Sweden
    5,148
    annotations is text (as far as I understand the word anyway).
    Blocks/text can be annotative = changes size depending on the scale.
    MTJIGSTRING = BAZINGA
  10. #10
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    HaHa!
    Sorry for the misinterpretation about annotative blocks. Just trying to help.
    Also take note the thread was not orignally about annotative blocks.
    By the that was your suggestion and attributes was mine. I am not trying
    to step on peoples toes. Since you are a moderator I would think you would
    understand this.
  1. Scaling C3D objects
    By Alioness in forum Civil 3D & LDD
    Last Post: 27th Mar 2009, 10:01 pm
  2. Scaling Small Objects
    By the_dynam1te in forum AutoCAD Beginners' Area
    Last Post: 31st Jul 2008, 06:41 am
  3. I have a question about scaling objects.
    By bluetoast in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Mar 2008, 09:24 pm
  4. Control when scaling objects
    By missymoo27 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Aug 2007, 02:50 pm
  5. Scaling multiple objects question
    By alderney in forum AutoCAD General
    Last Post: 14th Feb 2007, 12:54 am
