salman Posted May 10, 2009 Share Posted May 10, 2009 The way we place our cursor over an object (without actually clicking) and it becomes highlighted, similarly I want to write code that highlights certain portion of drawing, so that we can easily view it. For exampe I want to show the flow of water in pipes. If I hightlight the desired portion of pipes, In a drawing having thosands of other objects, the user will be able to easily view flow of water without caring about other objects present in thedrawing. Some users may suggest that I turn off other layers and keep the water pipe layer on, but we need to view the water pipes while other existing services suchs as ( telephone lines, undergroud electrictiy lines ) are also visible in the drawing. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted May 10, 2009 Share Posted May 10, 2009 Have you thought of using Layiso with the Settings > Lock and fade option? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 11, 2009 Share Posted May 11, 2009 (edited) Two options for you to play around with: (defun c:hlight (/ lLst lay ObjLst grdat iEnt) (vl-load-com) (vlax-for l (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq lLst (cons (vla-get-Name l) lLst))) (if (and (setq lay (strcase (getstring t "\nSpecify layer to Highlight: "))) (member lay (mapcar 'strcase lLst))) (progn (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay)))))) (princ "\nMove Cursor Over Objects....") (while (eq 5 (car (setq grdat (grread t 4 2)))) (if (and (setq iEnt (car (nentselp (cadr grdat)))) (eq lay (strcase (cdr (assoc 8 (entget iEnt)))))) (mapcar '(lambda (x) (redraw x 3)) ObjLst) (mapcar '(lambda (x) (redraw x 4)) ObjLst)))) (princ "\n<!> Layer not Found <!>")) (princ)) (defun c:hlight2 (/ lLst lay ObjLst NulLst grdat iEnt) (vl-load-com) (vlax-for l (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq lLst (cons (vla-get-Name l) lLst))) (if (and (setq lay (strcase (getstring t "\nSpecify layer to Highlight: "))) (member lay (mapcar 'strcase lLst))) (progn (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay))))) NulLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons -4 "<NOT") (cons 8 lay) (cons -4 "NOT>")))))) (princ "\nMove Cursor Over Objects....") (while (eq 5 (car (setq grdat (grread t 4 2)))) (if (and (setq iEnt (car (nentselp (cadr grdat)))) (eq lay (strcase (cdr (assoc 8 (entget iEnt)))))) (progn (mapcar '(lambda (x) (redraw x 3)) ObjLst) (mapcar '(lambda (x) (redraw x 2)) NulLst)) (progn (mapcar '(lambda (x) (redraw x 4)) ObjLst) (mapcar '(lambda (x) (redraw x 1)) NulLst))))) (princ "\n<!> Layer not Found <!>")) (princ)) Type "hlight" or "hlight2" to invoke Edited July 3, 2019 by Lee Mac Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 11, 2009 Share Posted May 11, 2009 (edited) This is actually probably more useful: (defun c:hlight3 (/ lay ObjLst NulLst grdat iEnt) (princ "\nMove Cursor Over Objects....") (while (eq 5 (car (setq grdat (grread t 4 2)))) (if (setq iEnt (car (nentselp (cadr grdat)))) (progn (setq lay (strcase (cdr (assoc 8 (entget iEnt))))) (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay))))) NulLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons -4 "<NOT") (cons 8 lay) (cons -4 "NOT>")))))) (mapcar '(lambda (x) (redraw x 3)) ObjLst) (mapcar '(lambda (x) (redraw x 2)) NulLst)) (if (and ObjLst NulLst) (progn (mapcar '(lambda (x) (redraw x 4)) ObjLst) (mapcar '(lambda (x) (redraw x 1)) NulLst))))) (princ)) Type "hlight3" to invoke Edited July 3, 2019 by Lee Mac Quote Link to comment Share on other sites More sharing options...
CAB Posted May 11, 2009 Share Posted May 11, 2009 Another method: Issue a regen to un highlite ;;============================================================= ;; Sel.lsp by Charles Alan Butler ;; Copyright 2004 ;; by Precision Drafting & Design All Rights Reserved. ;; Contact at ab2draft@TampaBay.rr.com ;; ;; Version 1.0 Beta July 23,2004 ;; Version 1.1 Beta July 13,2005 ;; ;; Creates a selection set of objects on a layer(s) ;; User picks objects to determine the layer(s) ;; Then User selects objects for ss or presses enter to ;; get all objects on the selected layer(s) ;; You may select the selection set before starting this ;; routine. Then select the layers to keep in the set ;;============================================================= (defun c:sel (/ ent lay ss lay:lst lay:prompt ss:first ent:lst) ;; An integer value that controls the visibility and highlighting of the entity. ;; The mode can be one of the following values: ;; 1 Show entity ;; 2 Hide entity (blank it out) ;; 3 Highlight entity ;; 4 Unhighlight entity (defun ssredraw ( ss mode / i ename vlaobj) (and (eq 'pickset (type ss)) (setq i -1) (while (setq ename (ssname ss (setq i (1+ i)))) (setq vlaobj (vlax-ename->vla-object (ssname ss i))) (vla-Highlight vlaobj :vlax-true) (vla-update vlaobj) ) ) ) ;; get anything already selected (setq ss:first (cadr(ssgetfirst)) ss (ssadd)) ;; Get user selected layers (if ss:first (setq lay:prompt "\nSelect the object to choose layers to keep.") (setq lay:prompt "\nSelect object(s) for layer filter. ENTER to continue.") ) (while (setq ent (entsel lay:prompt)) (setq ent:lst (cons (car ent) ent:lst)) (setq lay:lst (cons (setq lay (cdr(assoc 8 (entget (car ent))))) lay:lst)) (prompt (strcat "\n*-* Selected Layer -> " lay)) ) ;; Un HighLite the entities (and ent:lst (mapcar '(lambda (x) (redraw x 4)) ent:lst)) (if (> (length lay:lst) 0); got layers to work with (progn (setq lay "") (setq lay:lst (vl-sort lay:lst '<)) ; removes douplicates (foreach itm lay:lst ; combine lay names into one , del string (setq lay (strcat lay itm ","))) (setq lay (substr lay 1 (1- (strlen lay)))); remove the last , (if ss:first ; ALREADY GOT SELECTION SET (while (setq ent (ssname ss:first 0)) (if (member (cdr(assoc 8 (entget ent))) lay:lst) (ssadd (ssname ss:first 0) ss) ) (ssdel (ssname ss:first 0) ss:first) ) (progn ; else get a selection set to work with (prompt (strcat "\nOK >>--> Select objects for Selection set or " "ENTER for All objects on layer(s) " lay)) ;; get objects using filter with user select (if (null (setq ss (ssget (list (cons 8 lay))))) ;; or get ALL objects in current space using filter (setq ss (ssget "_X" (list (cons 8 lay)(cons 410 (getvar "ctab"))))) ) ) ) (if (> (sslength ss) 0) (progn (prompt (strcat "\n" (itoa (sslength ss)) " Object(s) selected on layer(s) " lay "\nStart an ACAD command, REGEN to un highlite.")) (ssredraw ss 3) ) (prompt "\n*** Nothing Selected ***") ) ) ) (princ) ) (prompt "\nSelect on Layer loaded, Enter Sel to run.") (princ) Quote Link to comment Share on other sites More sharing options...
EdilsonTS Posted November 10, 2021 Share Posted November 10, 2021 On 5/10/2009 at 9:00 PM, Lee Mac said: Two options for you to play around with: (defun c:hlight (/ lLst lay ObjLst grdat iEnt) (vl-load-com) (vlax-for l (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq lLst (cons (vla-get-Name l) lLst))) (if (and (setq lay (strcase (getstring t "\nSpecify layer to Highlight: "))) (member lay (mapcar 'strcase lLst))) (progn (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay)))))) (princ "\nMove Cursor Over Objects....") (while (eq 5 (car (setq grdat (grread t 4 2)))) (if (and (setq iEnt (car (nentselp (cadr grdat)))) (eq lay (strcase (cdr (assoc 8 (entget iEnt)))))) (mapcar '(lambda (x) (redraw x 3)) ObjLst) (mapcar '(lambda (x) (redraw x 4)) ObjLst)))) (princ "\n<!> Layer not Found <!>")) (princ)) (defun c:hlight2 (/ lLst lay ObjLst NulLst grdat iEnt) (vl-load-com) (vlax-for l (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq lLst (cons (vla-get-Name l) lLst))) (if (and (setq lay (strcase (getstring t "\nSpecify layer to Highlight: "))) (member lay (mapcar 'strcase lLst))) (progn (setq ObjLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons 8 lay))))) NulLst (mapcar 'cadr (ssnamex (ssget "_X" (list (cons -4 "<NOT") (cons 8 lay) (cons -4 "NOT>")))))) (princ "\nMove Cursor Over Objects....") (while (eq 5 (car (setq grdat (grread t 4 2)))) (if (and (setq iEnt (car (nentselp (cadr grdat)))) (eq lay (strcase (cdr (assoc 8 (entget iEnt)))))) (progn (mapcar '(lambda (x) (redraw x 3)) ObjLst) (mapcar '(lambda (x) (redraw x 2)) NulLst)) (progn (mapcar '(lambda (x) (redraw x 4)) ObjLst) (mapcar '(lambda (x) (redraw x 1)) NulLst))))) (princ "\n<!> Layer not Found <!>")) (princ)) Type "hlight" or "hlight2" to invoke the code highlight all the objects in the same layer and hide the others, theres a way just to highlight the object the cursor is over to show whitch line you will get selected if you click? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 11, 2021 Share Posted November 11, 2021 Maybe select a object then QP. Quote Link to comment Share on other sites More sharing options...
