After having inserted multiple blocks in a drawing, the attributes must be filled in. Now i use "ddatte" per block, so 100 blocks means 100 times ddatte and then fill in.
Another way is by selecting the blocks that are the same an then use "props" to fill out the fields.
Can it be done with lisp, like "global attribute edit"..?
i.e.: 1. invoke command like "gae" 2. prompt for reference block -> select block 3. get dialog (same as ddatte dialog box) 4. fill it out 5. select blocks (per block or via crossing) 6. selected blocks are filled out.
And is it possible to copy the attribute values of a block (that has been filled out) to another?
Got a million ideas but first this one !
Found the command "gatte" within the express menu.
I can and wil use it but how can the routine be modified so it does the thingy to all the attributes belonging to the block?
Ie. a block with 3 filled out attributes, copy all attributes to the other blocks.
;;; GATTE.LSP
;;; Copyright © 1999 by Autodesk, Inc.
;;; Your use of this software is governed by the terms and conditions of the
;;; License Agreement you accepted prior to installation of this software.
;;; Please note that pursuant to the License Agreement for this software,
;;; "[c]opying of this computer program or its documentation except as
;;; permitted by this License is copyright infringement under the laws of
;;; your country. If you copy this computer program without permission of
;;; Autodesk, you are violating the law."
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
(Defun C:gatte ( /
N ;selection set counter
CC ;changed counter
BN ;block name
TG ;tag name
ESel ;entity pick/name/list
EL ;entity list
EN ;entity name
PASS ;loop pass flag
TAGL ;list of valid tags for a block
TAGS ;String of valid tags for a block
TAGT ;Temp tag list
;TAG ;tag name in loop
TMP ;temporary variable
SS1 ;selection set of insert objects
XX X ;flag and counter
OLDCC ;previous count of changes for update test
A ;entity information in change loop
FL LA ;frozen layer check variables
na b
(acet-error-init
(List
(List "cmdecho" 0)
T ;flag. True means use undo for error clean up.
) ;list
);acet-error-init
(sssetfirst nil nil)
(Setq n 0
cc 0
(while (null Pass)
(initget "Block _Block")
;; (setq ESel (entsel "\nBlock name/<select block or attribute>: "))
(setq ESel (entsel "\nSelect block or attribute [Block name]: "))
(cond
((null ESel) (setq Pass 'T BN nil))
((= (type ESel) 'LIST) ;;pick selection
(setq EL (entget (car ESel)))
(if (= (cdr (assoc 0 EL)) "INSERT")
(setq BN (cdr (assoc 2 EL))
Pass 'T
ESel (nentselp (cadr ESel))
EL (entget (car Esel))
TG (if (= (cdr (assoc 0 EL)) "ATTRIB")
(cdr (assoc 2 EL))
nil
(prompt "\nSelected item not an INSERT.")
);end if
);end second conditional for picking attrib
((and (= (type ESel) 'STR) (= ESel "Block"))
(setq BN (getstring "\nEnter block name: "))
(if (tblsearch "BLOCK" BN)
(setq Pass 'T)
(prompt "\nInvalid block name.")
);end third conditional
);the conditional statement ends
) ;;end of Block Name entry.
(if BN (progn
(setq Pass nil
EN (cdr (assoc -2 (tblsearch "BLOCK" BN)))
(while EN
(setq EL (entget EN))
(if (= (cdr (assoc 0 EL)) "ATTDEF")
(setq TAGL (cons (cdr (assoc 2 EL)) TAGL)))
(setq EN (entnext EN))
)) ;;end if BN progn
(if TG (setq Pass 'T))
(if TAGL
(setq TAGS (car TAGL)
TAGT (cdr TAGL)
(foreach TAG TAGT
(setq TAGS (strcat TAGS " " TAG))
(while (and TAGS (null Pass))
(initget TAGS)
(prompt (strcat "\nKnown tag names for block: " TAGS))
(setq ESel (nentsel "\nSelect attribute or type attribute name: "))
(cond
((= (type ESel) 'STR)
(setq ESel (xstrcase ESel))
(if (member ESel TAGL)
(setq Pass 'T
TG ESel
(prompt "\nInvalid attribute name.")
(setq TG (cdr (assoc 2 (entget (car ESel)))))
(if TG
(setq Pass 'T)
) ;;end of Attribute Name entry.
(if (and BN (null TAGL))
(setq BN (prompt "\nThe block selected has no attributes!")))
(If (And BN TG)
(Progn
(prompt (acet-str-format "\nBlock: %1 Attribute tag: %2" BN TG))
(Setq
NA (GetString T "\nEnter new text: ")
SS1 (SsGet "_X"
(List
(Cons 0 "INSERT")
(Cons 2 bn)
(Cons 66 1)
N (If SS1 (SsLength SS1) 0)
(initget 0 "Yes No _Yes No")
(setq TMP
(getkword
(acet-str-format "\nNumber of inserts in drawing = %1 Process all of them? [Yes/No] <Yes>: " (itoa N))))
(if (and TMP (= TMP "No"))
(setq SS1 (ssget (list (cons 0 "INSERT")
(cons 2 BN)
(cons 66 1)))
N (if SS1 (sslength SS1) 0)
(if (> N 0) (Princ "\nPlease wait..."))
(setq x 0)
(repeat N
(setq A (ssname SS1 x)
B (entget A)
la (cdr (assoc 8 B)) ;layer name from object
fl (tblsearch "LAYER" la) ;table entry for layer
fl (cdr (assoc 70 fl)) ;layer status flag
(if (/= fl 65) ;if layer not frozen
(setq XX 1
oldcc cc)
(while XX
(setq
B (EntGet (EntNext (CDR (Assoc -1 B))))
(If (= (CDR (Assoc 0 B)) "SEQEND")
(Setq xx Nil)
(Progn
(If (= (CDR (Assoc 2 b)) tg)
(Progn
(Setq B (subst (Cons 1 NA) (assoc 1 B) B)
CC (1+ CC)
(EntMod B)
) ;progn
) ;if
) ;progn
) ;if
) ;while
(If (/= cc oldcc) (EntUpd a))
) ;progn
) ;if
(Setq X (1+ X))
) ;repeat
(If (/= 1 cc)
(princ (acet-str-format "\n%1 attributes changed." (itoa cc)))
(princ (acet-str-format "\n%1 attribute changed." (itoa cc)))
) ;progn
(acet-error-restore)
(Princ)
) ;defun
