Routine for Decomposition of Vectors
lizp
Hi Everyone, This is my first post in this forum I have no experience with Lisp but have found out recently how useful routines in AutoLISP can be. I've used plperp.lsp to draw perpendiculars to lines in AutoCAD as well as tlen.lsp to find lengths of segments. I should say that were not these small routines I would still be struggling with the tedious calculations I had to do with the not so user-friendly AutoCAD. The above experience led me to think that other activities can also be automated, at that not only to avoid tediousness but also to increase precision. So, here's what I wish I could find: Does anyone know if there's a routine which would allow to decompose a vector by, say, clicking on it, along the normal and the tangent at a given point of a curve and then decompose further the tangent component along the direction of the line connecting said point of the curve with the center of a circle and the perpendicular to that line? Finally I need to have the length of that perpendicular segment multiplied by the length of that line. I doubt that a routine doing all this would exist but maybe there would be elements of it, especially the vector decomposition part. Thanks for any help you might offer.
  • Replies 231
  • Lee Mac
    107
  • lizp
    99
  • SEANT
    24
  • The Buzzard
    2
Posted Images
Would you be able to attach a 2000 format drawing with a diagram depicting what you need to find - its hard to picture all that :oops:
Thanks
Lee
Please find attached an example of the first part of what I want the AutoLISP routine to do. The red segment is the vector to be decomposed. Green segments are the components of said vector along the normal and the tangent of the curve. These components can be found by hand but what I'm expecting is that there should be an AutoLISP routine to do this automatically.
After this is done the green tangential component should be further decomposed (not shown in this illustration to not burden it) into its components along the line depicted in Cyan which connects the point on the curve with the center of the circle on the one hand and the perpendicular to that line on the other. Finally the length of that line is to be multiplied by the length of the component of the initial vector perpendicular to said line.
vector_decomposition_along_normal_and_tangent.dxf
So are you saying that the user will pick the red line and the curve?
Correct. Only the particular point on the curve has to be picked, however.
How this for starters:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:vec [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] doc spc Circ cCen grdat cEnt cObj pt tan tanpt norpt ptlst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-Acad-Object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     spc [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-activespace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]=[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-mspace[/color][/b] doc[b][color=RED])[/color][/b] :vlax-true[b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vla-get-paperspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]vla-get-modelspace[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Circ [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Circle: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"CIRCLE"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] Circ[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cCen [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] Circ[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nSelect Curve: "[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#009900]5[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] grdat [b][color=RED]([/color][/b][b][color=BLUE]grread[/color][/b] [b][color=BLUE]t[/color][/b] [b][color=#009900]5[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] vs [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"VIEWSIZE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cEnt [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentselp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                          [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"LWPOLYLINE"[/color][/b] [b][color=#ff00ff]"POLYLINE"[/color][/b] [b][color=#ff00ff]"CIRCLE"[/color][/b]
                            [b][color=#ff00ff]"ELLIPSE"[/color][/b] [b][color=#ff00ff]"ARC"[/color][/b]  [b][color=#ff00ff]"LINE"[/color][/b] [b][color=#ff00ff]"SPLINE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] Circ cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b] cEnt [b][color=#009900]3[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cObj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] cEnt[b][color=RED])[/color][/b]
                 pt [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] cObj [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] grdat[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 tan  [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getFirstDeriv[/color][/b] cObj
                        [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] cObj pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 tanpt [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] tan[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] vs [b][color=#009999]4.0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 norpt [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pi [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] tan[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] vs [b][color=#009999]4.0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]grvecs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]3[/color][/b] pt tanpt [b][color=#009900]3[/color][/b] pt norpt [b][color=#009900]4[/color][/b] pt cCen[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b] x [b][color=#009900]4[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b]
                         [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] cEnt
         [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ptlst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-3d-point[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] pt tanpt norpt cCen[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acRed[b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acRed[b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadddr[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acCyan[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> No Circle Selected <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b] [b][color=#ff00ff]"_regenall"[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Thanks Lee. That looks like a step in the right direction. However, what needs to be done is to select the Red line (the vector in question) whose components are to be found along the normal and the tangent to the curve as well as select the curve.
In your code the circle is selected first and then when selecting the curve, aside from the properly drawn radius, the components of the vector are not recalculated. Say, for instance, you draw a longer vector that needs to be decomposed -- you'll see that the components your code draws aren't the ones that correspond to the new vector but are retained, that is, are the already existing components from the original vector.
My code merely displays the tangent and normal vectors of that particular point on the curve.
I shall modify it to see what I can do :)
This sounds like an interesting problem – and I see you are in good hands. Do you mind me asking what is the real world situation this geometry is modeling?
Give this a shot:
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bVec [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Base Vector: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"LINE"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] bVec[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           lObj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] bVec[b][color=RED])[/color][/b]
           lAng [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
                  [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getFirstDeriv[/color][/b] bVec
                    [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getStartParam[/color][/b] bVec[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           lLen [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Length[/color][/b] lObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 angdif [b][color=RED]([/color][/b][b][color=BLUE]abs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] tan[b][color=RED])[/color][/b] lAng[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 tanpt [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] tan[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] lLen [b][color=RED]([/color][/b][b][color=BLUE]cos[/color][/b] angdif[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 norpt [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pi [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] tan[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] lLen [b][color=RED]([/color][/b][b][color=BLUE]sin[/color][/b] angdif[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 bsvpt [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt lAng lLen[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]grvecs[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=#009900]3[/color][/b] pt tanpt [b][color=#009900]3[/color][/b] pt norpt [b][color=#009900]4[/color][/b] pt cCen [b][color=#009900]1[/color][/b] pt bsvpt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ptlst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-3d-point[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] pt tanpt norpt cCen bsvpt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cadr[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acGreen[b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]caddr[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acGreen[b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-put-color[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-addline[/color][/b] spc [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] ptlst[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]last[/color][/b] ptlst[b][color=RED])[/color][/b][b][color=RED])[/color][/b] acRed[b][color=RED])[/color][/b]
Lee, I think this is absolutely fantastic. Can't believe my eyes.
Is it possible now to apply the same concept and decompose the obtained tangential component further into a component along the radial line and, especially important, a component along the perpendicular to the radial line?
