Results 1 to 9 of 9
    Forum Newbie Rosco's Avatar
    AutoCAD LT 2009
    May 2009
    UK
    7
    Default Is there a way to Crop images inserted into a dwg?
    Hi
    Is there a way to crop images inserted into a dwg? The method I used to insert was simply to right click an image on a website 'copy' / right click in CAD 'paste' rather than insert OLE.
    Thx
    Super Member
    ronjonp's Computer Details
    Windows 10
    AutoCAD 2018
    Apr 2009
    Colorado
    681
    Take a look at the IMAGECLIP command.
    AutoCAD LT 2009
    May 2009
    UK
    7
    Sorry i should of said i am using Autocad 2008 LT today.
    Any ideas for 2008 LT?
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Crop the saved image in Paintshop or any image editor outside of AutoCAD.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,170
    Use paperspace viewports to clip .
    Had a project done by some one else so had pdfs only we added our own images and used viewports polygon to clip and add to make a new visual effect where we removed some detail and added our own. (images were aerial phots from the same source)
  6. #6
    Forum Newbie
    Multi-disciplinary
    AutoCAD 2017
    May 2017
    Stoke-On-Trent
    6
    Laughing I've got you!
    A little late to the scene but if you select the image, right click, image, clip, and new boundary. Select the top/bottom corners of the side you want to keep, drag across.
    Purely as a side not, I was trying to work this out in AutoCAD LT and couldn't find a straight answer, so I hope this is as straight as it comes.
  7. #7
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    8 years isn't just late.
    Drafting is a breeze.
  8. #8
    Forum Newbie
    Multi-disciplinary
    AutoCAD 2017
    May 2017
    Stoke-On-Trent
    6
    Clearly not, you're here. And that means someone else could be too... Just trying to help
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    The thing is when a topic gets a new response, it gets moved from way down the list to the top. It's good that you are trying to help.
  1. crop on autocad lt 2004
    By alexwebb80 in forum AutoCAD Beginners' Area
    Last Post: 15th Apr 2009, 11:37 am
  2. Clip/crop An Xref
    By hp63 in forum AutoCAD General
    Last Post: 3rd Jun 2008, 10:21 am
  3. image to big need to crop
    By tsurvey in forum AutoCAD General
    Last Post: 5th May 2008, 09:51 pm
  4. Replies: 0
    Last Post: 27th Jan 2007, 12:00 am
  5. Crop
    By Niz in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jun 2006, 10:43 pm
