CadTechJGC184 Posted May 18, 2009 Share Posted May 18, 2009 I’ve been looking for the Edit text command and I’m having no luck. I want to be able to pick more then one text at a time to change. Like I have 6 to change and I pick one after another and then it lets me edit them in the order I picked them. At my last job we used ETA. Any help?? Quote Link to comment Share on other sites More sharing options...
CadTechJGC184 Posted May 18, 2009 Author Share Posted May 18, 2009 oops...... got it! ; EDIT ATTRIBUTED OR TEXT BY SELECTION (defun C:ETA (/ A B C D E F G H J K L M N ) (graphscr) ; (prompt "\nEdit-TEXT/ATTRIBUTE is loaded... ") (setq A (ssget) B (sslength A) C 0) (while ( (setq F (car E)) (setq G (cdr E)) (setq H (car G)) (setq J (cdr H)) (setq K "TEXT") (setq L "INSERT") (setq M "DIMENSION") (setq N "MTEXT") (if (= J K) (command ".ddedit" D "")) (if (= J N) (command ".ddedit" D "")) (if (= J L) (command ".ddatte" D )) (if (= J M) (prompt "\n You have picked a dimension YOU MORON...., I only do text or attributes ...")) (terpri) (setq C (1+ C))) (princ) ) Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 18, 2009 Share Posted May 18, 2009 Here's mine, if you'd like. It works on Text, MText, Attributes, Dimensions and even text within a block (though, keep in mind, it'll change every instance of the block... for now) ;Super-Edit ;by Mark Mercier ;05-11-09 (defun c:ed( / )(super_edit)) (defun c:at( / )(super_edit)) (defun super_edit( / modEnt dumEnt ent) (vl-load-com) (while (setq ent (nentsel "\nSelect object: ")) (if (and ent (or (wcmatch (cdadr (entget (car ent))) "*TEXT") (eq "ATTRIB" (cdadr (entget (car ent)))))) (progn ; Extract properties of selection and save as list, to modify or replace later if failed (setq modEnt (vlax-ename->vla-object (car ent))) ; extract properties and create dummy text (setq dumEnt (_TextCopy ent)) ; Clear contents of selected text (vla-put-TextString modEnt " ") (command "regen") ; Edit dummy text (command "DDEDIT" (entlast))(command) ; once DDEDIT is finished, set modEnt TextString equal to dumEnt (if (and (caar (cdddr ent)) (wcmatch (vla-get-ObjectName (vlax-ename->vla-object (caar (cdddr ent)))) "*Dimension")) (vla-put-TextOverride (vlax-ename->vla-object (caar (cdddr ent))) (vla-get-TextOverride (vlax-ename->vla-object dumEnt))) (vla-put-TextString modEnt (vla-get-TextString (vlax-ename->vla-object dumEnt))) ) ; Delete dummy text (command "erase" dumEnt "") (command "regen") ) ) ) ) (defun _TextCopy(ent / vlaEnt lasEnt return) (setq return nil) (cond ((and (wcmatch (cdadr (entget (car ent))) "TEXT") (not (caar (cdddr ent)))) (setq return (_TextCopy-TEXT ent)) ) ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (not (caar (cdddr ent)))) (setq return (_TextCopy-MTEXT ent)) ) ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (eq "INSERT" (cdr (assoc 0 (entget (caar (cdddr ent))))))) (setq return (_TextCopy-NESMTEXT ent)) ) ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (eq "DIMENSION" (cdr (assoc 0 (entget (caar (cdddr ent))))))) (setq return (_TextCopy-DIMMTEXT ent)) ) ((and (wcmatch (cdadr (entget (car ent))) "TEXT") (not (assoc 410 (entget (car ent))))) (setq return (_TextCopy-NESTEXT ent)) ) ((eq "ATTRIB" (cdadr (entget (car ent)))) (setq return (_TextCopy-NESATT ent)) ) ) return ); Creates exact copy of text/mtext/attribute entity as text/mtext, including blocked text. Return entity if successful or nil if not. (defun _TextCopy-TEXT(ent / vlaEnt lasEnt) (command "TEXT" '(0 0 0) 1 1 "1") (setq lasEnt (vlax-ename->vla-object (entlast))) (setq vlaEnt (vlax-ename->vla-object (car ent))) (vla-put-Layer lasEnt (vla-get-Layer vlaEnt)) (vla-put-Height lasEnt (vla-get-Height vlaEnt)) (vla-put-TextString lasEnt (vla-get-TextString vlaEnt)) (vla-put-Rotation lasEnt (vla-get-Rotation vlaEnt)) (vla-put-ScaleFactor lasEnt (vla-get-ScaleFactor vlaEnt)) (vla-put-ObliqueAngle lasEnt (vla-get-ObliqueAngle vlaEnt)) (vla-put-StyleName lasEnt (vla-get-StyleName vlaEnt)) (vla-put-Alignment lasEnt (vla-get-Alignment vlaEnt)) (vla-put-Backward lasEnt (vla-get-Backward vlaEnt)) (vla-put-Normal lasEnt (vla-get-Normal vlaEnt)) (vla-put-UpsideDown lasEnt (vla-get-UpsideDown vlaEnt)) (vla-put-InsertionPoint lasEnt (vla-get-InsertionPoint vlaEnt)) (vla-put-TextAlignmentPoint lasEnt (vla-get-TextAlignmentPoint vlaEnt)) (setq return (vlax-vla-object->ename lasEnt)) return ) (defun _TextCopy-MTEXT(ent / vlaEnt lasEnt) (command "MTEXT" '(0 0 0) '(1 1 0) "1" "") (setq lasEnt (vlax-ename->vla-object (entlast))) (setq vlaEnt (vlax-ename->vla-object (car ent))) (vla-put-AttachmentPoint lasEnt (vla-get-AttachmentPoint vlaEnt)) (vla-put-InsertionPoint lasEnt (vla-get-InsertionPoint vlaEnt)) (vla-put-Layer lasEnt (vla-get-Layer vlaEnt)) (vla-put-Height lasEnt (vla-get-Height vlaEnt)) (vla-put-TextString lasEnt (vla-get-TextString vlaEnt)) (vla-put-Width lasEnt (vla-get-Width vlaEnt)) (vla-put-StyleName lasEnt (vla-get-StyleName vlaEnt)) (vla-put-Normal lasEnt (vla-get-Normal vlaEnt)) (vla-put-BackgroundFill lasEnt (vla-get-BackgroundFill vlaEnt)) (vla-put-DrawingDirection lasEnt (vla-get-DrawingDirection vlaEnt)) (vla-put-LineSpacingDistance lasEnt (vla-get-LineSpacingDistance vlaEnt)) (vla-put-LineSpacingFactor lasEnt (vla-get-LineSpacingFactor vlaEnt)) (vla-put-LineSpacingStyle lasEnt (vla-get-LineSpacingStyle vlaEnt)) (vla-put-Rotation lasEnt (vla-get-Rotation vlaEnt)) (setq return (vlax-vla-object->ename lasEnt)) return ) (defun _TextCopy-NESATT(ent / vlaEnt lasEnt) (command "TEXT" '(0 0 0) 1 1 "1") (setq lasEnt (vlax-ename->vla-object (entlast))) (setq vlaEnt (vlax-ename->vla-object (car ent))) (vla-put-Layer lasEnt (vla-get-Layer vlaEnt)) (vla-put-InsertionPoint lasEnt (vla-get-InsertionPoint vlaEnt)) (vla-put-Height lasEnt (vla-get-Height vlaEnt)) (vla-put-TextString lasEnt (vla-get-TextString vlaEnt)) (vla-put-Rotation lasEnt (vla-get-Rotation vlaEnt)) (vla-put-ScaleFactor lasEnt (vla-get-ScaleFactor vlaEnt)) (vla-put-ObliqueAngle lasEnt (vla-get-ObliqueAngle vlaEnt)) (vla-put-StyleName lasEnt (vla-get-StyleName vlaEnt)) (princ "blah") (setq return (vlax-vla-object->ename lasEnt)) return ) (defun _TextCopy-NESTEXT(ent / vlaEnt lasEnt) (command "TEXT" '(0 0 0) 1 1 "1") (setq lasEnt (vlax-ename->vla-object (entlast))) (setq vlaEnt (vlax-ename->vla-object (car ent))) (vla-put-TextString lasEnt (vla-get-TextString vlaEnt)) (vla-put-ObliqueAngle lasEnt (vla-get-ObliqueAngle vlaEnt)) (vla-put-StyleName lasEnt (vla-get-StyleName vlaEnt)) (vla-put-Alignment lasEnt (vla-get-Alignment vlaEnt)) (vla-put-Backward lasEnt (vla-get-Backward vlaEnt)) (vla-put-Normal lasEnt (vla-get-Normal vlaEnt)) (vla-put-UpsideDown lasEnt (vla-get-UpsideDown vlaEnt)) (vla-put-Height lasEnt (vlax-make-variant (* (cdr (assoc 42 (entget (caar (cdddr ent))))) (cdr (assoc 40 (entget (car ent))))) vlax-vbDouble)) (vla-put-ScaleFactor lasEnt (vlax-make-variant (* (/ (cdr (assoc 41 (entget (caar (cdddr ent))))) (cdr (assoc 42 (entget (caar (cdddr ent)))))) (cdr (assoc 41 (entget (car ent))))) vlax-vbDouble)) (vla-put-Rotation lasEnt (vlax-make-variant (cdr (assoc 50 (entget (caar (cdddr ent))))) vlax-vbDouble)) (vla-put-Layer lasEnt (vlax-make-variant (cdr (assoc 8 (entget (caar (cdddr ent))))) vlax-vbString)) (vla-put-InsertionPoint lasEnt (vlax-3D-point (+ (car (cdr (assoc 10 (entget (caar (cdddr ent)))))) (car (cdr (assoc 10 (entget (car ent)))))) (+ (cadr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (cadr (cdr (assoc 10 (entget (car ent)))))) (+ (caddr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (caddr (cdr (assoc 10 (entget (car ent)))))))) (vla-put-TextAlignmentPoint lasEnt (vlax-3D-point (+ (car (cdr (assoc 10 (entget (caar (cdddr ent)))))) (car (cdr (assoc 11 (entget (car ent)))))) (+ (cadr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (cadr (cdr (assoc 11 (entget (car ent)))))) (+ (caddr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (caddr (cdr (assoc 11 (entget (car ent)))))))) (setq return (vlax-vla-object->ename lasEnt)) return ) (defun _TextCopy-NESMTEXT(ent / vlaEnt lasEnt) (command "MTEXT" '(0 0 0) '(1 1 0) "1" "") (setq lasEnt (vlax-ename->vla-object (entlast))) (setq vlaEnt (vlax-ename->vla-object (car ent))) (vla-put-TextString lasEnt (vla-get-TextString vlaEnt)) (vla-put-StyleName lasEnt (vla-get-StyleName vlaEnt)) (vla-put-Normal lasEnt (vla-get-Normal vlaEnt)) (vla-put-AttachmentPoint lasEnt (vla-get-AttachmentPoint vlaEnt)) (vla-put-Width lasEnt (vla-get-Width vlaEnt)) (vla-put-Height lasEnt (vlax-make-variant (* (cdr (assoc 42 (entget (caar (cdddr ent))))) (cdr (assoc 40 (entget (car ent))))) vlax-vbDouble)) (vla-put-Rotation lasEnt (vlax-make-variant (cdr (assoc 50 (entget (caar (cdddr ent))))) vlax-vbDouble)) (vla-put-Layer lasEnt (vlax-make-variant (cdr (assoc 8 (entget (caar (cdddr ent))))) vlax-vbString)) (vla-put-InsertionPoint lasEnt (vlax-3D-point (+ (car (cdr (assoc 10 (entget (caar (cdddr ent)))))) (car (cdr (assoc 10 (entget (car ent)))))) (+ (cadr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (cadr (cdr (assoc 10 (entget (car ent)))))) (+ (caddr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (caddr (cdr (assoc 10 (entget (car ent)))))))) (setq return (vlax-vla-object->ename lasEnt)) return ) (defun _TextCopy-DIMMTEXT(ent / vlaEnt lasEnt) (command "copybase" (list 0 0 0) (caar (cdddr ent)) "") (command "pasteclip" (list 0 0 0)) (setq return (entlast)) return ) There's probably a few pieces of code that could be cleaned up, but all in all, it -should- work. It's still a work-in-progress. Let me know how it works, if you use it. I use it myself quite often. ^^ Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 18, 2009 Share Posted May 18, 2009 Just a quick one: [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:qEdit [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss dc$tag bs|Txt nw|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] dc$tag [b][color=RED]([/color][/b][b][color=BLUE]load_dialog[/color][/b] [b][color=#ff00ff]"ACAD"[/color][/b][b][color=RED])[/color][/b] bs|Txt [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]new_dialog[/color][/b] [b][color=#ff00ff]"acad_txtedit"[/color][/b] dc$tag[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]set_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] bs|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] [b][color=#ff00ff]"(setq nw|Txt $value)"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"cancel"[/color][/b] [b][color=#ff00ff]"(exit)"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]start_dialog[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] nw|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] x[b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]unload_dialog[/color][/b] dc$tag[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote Link to comment Share on other sites More sharing options...
Commandobill Posted May 18, 2009 Share Posted May 18, 2009 oops...... got it! ; EDIT ATTRIBUTED OR TEXT BY SELECTION (defun C:ETA (/ A B C D E F G H J K L M N ) (graphscr) ; (prompt "\nEdit-TEXT/ATTRIBUTE is loaded... ") (setq A (ssget) B (sslength A) C 0) (while ( (setq F (car E)) (setq G (cdr E)) (setq H (car G)) (setq J (cdr H)) (setq K "TEXT") (setq L "INSERT") (setq M "DIMENSION") (setq N "MTEXT") (if (= J K) (command ".ddedit" D "")) (if (= J N) (command ".ddedit" D "")) (if (= J L) (command ".ddatte" D )) (if (= J M) (prompt "\n You have picked a dimension YOU MORON...., I only do text or attributes ...")) (terpri) (setq C (1+ C))) (princ) ) as ddedit works on just about everything i changed your code just a little bit ; EDIT ATTRIBUTED OR TEXT BY SELECTION (defun C:ETA (/ A B C D E Z) (graphscr) ; (prompt "\nEdit-TEXT/ATTRIBUTE is loaded... ") (setq A (ssget) B (sslength A) C 0) (while (< C B) (setq D (ssname A C) E (entget D)) (setq Z (cdadr E)) (if (member Z '("TEXT" "MTEXT" "INSERT" "DIMENSION")) (command ".ddedit" D "")) (terpri) (setq C (1+ C))) (princ) ) I'm sure there was something else i wanted to do with it but i dont remember Quote Link to comment Share on other sites More sharing options...
Commandobill Posted May 18, 2009 Share Posted May 18, 2009 Just a quick one: [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:qEdit [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss dc$tag bs|Txt nw|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] dc$tag [b][color=RED]([/color][/b][b][color=BLUE]load_dialog[/color][/b] [b][color=#ff00ff]"ACAD"[/color][/b][b][color=RED])[/color][/b] bs|Txt [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]new_dialog[/color][/b] [b][color=#ff00ff]"acad_txtedit"[/color][/b] dc$tag[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]set_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] bs|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] [b][color=#ff00ff]"(setq nw|Txt $value)"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"cancel"[/color][/b] [b][color=#ff00ff]"(exit)"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]start_dialog[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] nw|Txt[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] x[b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]unload_dialog[/color][/b] dc$tag[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Hmm... doesnt seem like your style Lee. Trying something new? Quote Link to comment Share on other sites More sharing options...
