richard3009 Posted May 21, 2009 Share Posted May 21, 2009 I wish to place mulitiline text with middle center justification precisely in the centre of a rectangle how is this done. THANKYOU IN ADVANCVE Quote Link to comment Share on other sites More sharing options...
NBC Posted May 21, 2009 Share Posted May 21, 2009 In your rectangle, draw a diagonal line from one corner to the opposite corner. Create your MText entity (remembering to give it the justification you require). Click the MText entity, select the grip at the justification point, and move it to the midpoint of the diagonal line you created above. Erase the diagonal line. Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 21, 2009 Share Posted May 21, 2009 or use the "Mid between 2 points" object snap on the diagonal corners Quote Link to comment Share on other sites More sharing options...
jonesy Posted May 21, 2009 Share Posted May 21, 2009 I use the OTRACK with one of my snaps permanently set to mid. Quote Link to comment Share on other sites More sharing options...
richard3009 Posted May 21, 2009 Author Share Posted May 21, 2009 struggling here, when using the multiline placement box I click on opposite corners of the rectangle but the text goes anywhere but in the rectangle Quote Link to comment Share on other sites More sharing options...
jonesy Posted May 21, 2009 Share Posted May 21, 2009 Which method are you trying? Quote Link to comment Share on other sites More sharing options...
richard3009 Posted May 21, 2009 Author Share Posted May 21, 2009 I click on the multiline text placement icon, I then click on each diagonal corner of the rectangle, and this would normally create a multiline box where I could justify my text to suit, but it all gone belly up Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 21, 2009 Share Posted May 21, 2009 I do like NBC suggested in that I create the MTEXT first, then move it. Quote Link to comment Share on other sites More sharing options...
richard3009 Posted May 21, 2009 Author Share Posted May 21, 2009 sure I can do that, but it must be possible to place the text in the correct place first time Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 21, 2009 Share Posted May 21, 2009 are you using this button? Quote Link to comment Share on other sites More sharing options...
richard3009 Posted May 21, 2009 Author Share Posted May 21, 2009 Yes i use that button and it gives me midpoint, I have sussed what was wrong when placing the multiline box the default text size is set at 100mm instead of 2.5mm, how do I clear that dropdown list and make 2.5 my default Quote Link to comment Share on other sites More sharing options...
NBC Posted May 21, 2009 Share Posted May 21, 2009 When creating the MText, after you have picked the first corner of the rectangle (and BEFORE you click the second corner of the rectangle) enter H at the commandline, and set your text height to your desire. This will then become the default for all future MText creations for that particular drawing. Quote Link to comment Share on other sites More sharing options...
richard3009 Posted May 21, 2009 Author Share Posted May 21, 2009 Great stuff thats sorted it thankyou, is it possible to purge that text dropdown list that contains all your previous used text sizes. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 21, 2009 Share Posted May 21, 2009 I use a tool button with this macro ^C^C(initdia)(COMMAND ".MTEXT" PAUSE "J" "MC") After picking the button, simply snap to the opposite corners of the rectangle with endp or int osnaps. Quote Link to comment Share on other sites More sharing options...
