vweavers Posted May 21, 2009 Share Posted May 21, 2009 I am interested in making a 'catalog' of profiles our company has, using either Excel or Access. For the catalog purposes, the Excel or Access Database would use a simple 2D polyline profile created in each AutoCAD drawing. If I copy a polyline, and insert it into Excel- The polyline takes up only about 5% of the entire block that is inserted into the spreadsheet. This isn't suitable for being able to put 20+ 'thumbnails' on a cataloged page. Does anyone have any thoughts or ideas on the subject? We have nearly a thousand profiles to catalog, so we don't want to spend an inordinate amount of time on each profile. I'm a self-taught AutoCAD user- I'd classify myself as an intermediate user. Thanks! Vince Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2009 Share Posted May 21, 2009 Why can't the profiles be saved as jpg files and inserted in the catalog? Quote Link to comment Share on other sites More sharing options...
aLiCaD Posted May 21, 2009 Share Posted May 21, 2009 Sir, try also to convert it first in PDF so that you can post it in excel all. Quote Link to comment Share on other sites More sharing options...
Rob-GB Posted May 22, 2009 Share Posted May 22, 2009 Why not scale them to the actual size you need them to print out at then copy and paste into the correctly sized merged cells. Its how have done it in the past. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Patrick Hughes Posted May 22, 2009 Share Posted May 22, 2009 Are your profiles individual drawings that display a preview thumnail? If so have a look at a program of mine called DwgGrid - it will allow you to save your selected previews to a jpg that could then be inserted into the excel spreadsheet. Quote Link to comment Share on other sites More sharing options...
