Results 1 to 7 of 7
Thread: Two errors
    Full Member
    AutoCAD 2012
    Dec 2008
    Dallas, TX.
    72
    Default Two errors
    I'm using auto cad 2008 and I was trying to copy some object form one drawing to another but I keep getting an invaliad message, so I tried to insert the drawing as block that is when I got this
    Fatal error: 0x60008004 Exception at 6212f33bh.
    I shut down auto cad and tried once more and got this
    Fatal error: 0x7e01584 Exception at 6212f32ch.
    Does anyone know what would cause this?
    Just a minor set back for a major come back!
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Do an AUDIT first on the drawing before you try to insert it.
    The drawing may have corrupt data and Audit will fix this.
    Last edited by The Buzzard; 21st May 2009 at 03:59 pm. Reason: Added additional note
    Full Member
    AutoCAD 2012
    Dec 2008
    Dallas, TX.
    72
    AUDIT did not work.
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    When you did the AUDIT, Did you do it several times to ensure all errors in the drawing were fixed and after that you would also need to save the drawing before inserting into the other drawing?
    Also, Not sure if it is installed on your system, Do you have service pack 1 from Autodesk for version 2008?
  5. #5
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    SAM_R
    Can you upload the drawing you are trying to insert so we can see whats going on?.
  6. #6
    Full Member
    AutoCAD 2012
    Dec 2008
    Dallas, TX.
    72
    I do have the service pack. I can not upload because file is to big, but i did get the problem fix. I ran AUDIT a few more times and got it to work thank you.
  7. #7
    Forum Deity
    AutoCAD 2009
    Oct 2008
    2,112
    Good deal!
  1. Errors with blocks!!!!
    By neekcotrack in forum MEP
    Last Post: 7th Nov 2008, 08:53 pm
  2. LISP for Errors...
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Aug 2008, 06:14 pm
  3. file errors
    By DJB in forum AutoCAD General
    Last Post: 11th Aug 2008, 06:50 pm
  4. Profile errors
    By PaulR in forum AutoCAD Beginners' Area
    Last Post: 28th Feb 2007, 09:09 pm
  5. eNotThatKindofObject errors
    By 10west in forum AutoCAD Drawing Management & Output
    Last Post: 24th Mar 2006, 02:15 pm
