If you go to "File" "Open" you will see inventor parts/assemblies as a file type that you can open. I don't believe there's any sort of importing or 3rd party file translation required. I'm running SW 2009 and all the feature info is there.
does anyone know of a way to import inventor files into solid works 2009 and still retain all the feature info. we have tried step files and we have also tried opening the ipt files but we cant get arounf all the features comming in as import. we would like to open these Inventor file with full funcionality in Soildworks 2009, and i was wondering if there is a 3rd party software out there or some other way to allow us to do this.
thanks in advance
thanks for the reply
i have tried that and i can open the files succesfully, but when i open up a feature it shows as imported and i cant modify any of the original features.
You cannot retain the feature history tree. Use the Tools>Addins Feature Recognition to rebuild a feature tree.
Autodesk Inventor 2013 Certified Professional
http://home.pct.edu/~jmather/content..._Tutorials.htm
i found this in a search.
http://www.javelin-tech.com/main/pro...atureworks.htm
im not sure how the built in Feature Recognition will work on sheet metal parts but you should be able to convert the solid into sheetmetal and modify it. however modifying your original sketches may be too much to ask![]()
Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
Current Software: SolidWorks11,SolidCam11
http://www.solidworkslessons.info/
www.mysolidbox.com
