Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Full Member
    AutoCAD 2009
    Mar 2005
    46
    Default Leader/text to multileader
    I'm looking for a way to convert leader and text that is separate into a multileader where the text is attached to the leader. We just updated to new standards using the multileader and all the old stuff is not attached.
    I'm using AutoCad 2009.
    Thanks in advance.
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    Full Member
    AutoCAD 2009
    Mar 2005
    46
    Quote Originally Posted by lpseifert View Post
    That is exactly what I was looking for. You just made my life here so much easier!
    Thanks so much!
    Forum Deity NBC's Avatar
    AutoCAD 2009
    Aug 2007
    Manchester, UK
    2,109
    Be aware when using that routine that the exact positioning of the Multi-Leader Text that replaces the QLeader Text may not be at the same point.
    Life's constantly changing - keep up or get left behind
  5. #5
    Full Member
    AutoCAD 2009
    Mar 2005
    46
    Quote Originally Posted by NBC View Post
    Thanks for your concern but the text is actually attaching right where I need it to. (Or should I say where the company wants it to)
    I'm not sure I like where the text attaches (In the middle of the note) because to me it goes against all drafting practices that I was taught years ago.
  6. #6
    Forum Newbie
    AutoCAD 2011
    Dec 2011
    Saddle Brook, NJ
    2
    Default Does it works in 2012?
    Hi I am using 2012 and after selecting the leader + text is asking for location and then again for text.
  7. #7
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Quote Originally Posted by Bigbongo View Post
    It works.
    I wouldn't say its that accurate with regards to the justification as above though.
  8. #8
    Forum Newbie
    AutoCAD 2011
    Dec 2011
    Saddle Brook, NJ
    2
    Hi "super member", can you be a little more explicit? Justification is not important now, however put together leader + text will be very useful to update old dwg. I am missing something??? I am selecting the old leader with no place for text, just the arrow and the text is a multitext entity. Please let me know TX
    Newbie member!!!
  9. #9
    Forum Newbie
    AutoCAD 2015
    Jun 2008
    5
    Hello all, this lisp works great but i would like to know if someone can do a slight modification. The reason i am using this lisp is because i have many drawings where the leaders have been exploded. So i would like to replace the text and exploded leaders with multileaders. I wont the new multileader to be in the same place as the old one so what i would like to do is pick the leaders to delete but not actually delete them until i can pick the points to where they are for the new leader. This way i don't lose the existing position of the existing leaders. I hope this make sense. Can anyone help me with this. The lisp is below.
    (defun c:am (/ newleader pt1 pt2 ss txt x w rjp-getbbwdth)
    (vl-load-com)
    (defun rjp-getbbwdth (obj / out ll ur)
    (vla-getboundingbox obj 'll 'ur)
    (setq out (mapcar 'vlax-safearray->list (list ll ur)))
    (distance (car out) (list (caadr out) (cadar out)))
    (if (setq ss (ssget '((0 . "*TEXT"))))
    (progn (setq txt (apply
    'strcat
    (mapcar
    'cdr
    (vl-sort
    (mapcar '(lambda (x)
    (cons (vlax-get x 'insertionpoint)
    (strcat (vlax-get x 'textstring) " ")
    (setq
    ss (mapcar
    'vlax-ename->vla-object
    (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (function (lambda (y1 y2) (< (cadr (car y2)) (cadr (car y1))))
    w (car (vl-sort (mapcar 'rjp-getbbwdth ss) '>))
    txt (apply 'strcat
    (mapcar 'chr (reverse (cdr (reverse (vl-string->list txt)))))
    (mapcar 'vla-delete ss)
    (if (and (setq pt1 (getpoint "\nSpecify leader arrowhead location: "))
    (setq pt2 (getpoint pt1 "\nSpecify landing location: "))
    (progn (command "._MLEADER" pt1 pt2 "")
    (setq newleader (vlax-ename->vla-object (entlast)))
    (vla-put-textstring newleader txt)
    (vla-put-textwidth newleader w)
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,096
    Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[CODE]Your Code Here[/CODE] =
    Code:
    Your Code Here
  1. Multileader text
    By alijahed in forum AutoCAD General
    Last Post: 2nd Mar 2009, 09:58 am
  2. Cannot Edit Multileader Text
    By rustysilo in forum AutoCAD General
    Last Post: 2nd Feb 2009, 04:38 pm
  3. Autocad 2008 - Multileader Text Styles
    By nycadguy in forum AutoCAD General
    Last Post: 11th Dec 2008, 07:50 pm
  4. Multileader text at arrowhead end?
    By bbohannon1 in forum AutoCAD General
    Last Post: 13th Oct 2008, 07:11 pm
  5. MultiLeader text frame
    By lpseifert in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Jun 2008, 04:49 pm
