Macro problem with area
hey,
i want to insert a text with the total area of objects i've selected.
the problem is i can't seem to get out of the area command to start the text command. i've created a button for it wich runs the command.
this is how it looks:
^C^Carea;a;o;\Text;\;$m=$(/,$(fix,$(/,$(getvar,area),10000)),100)m²;
seperate the command seems to do the trick though.
first:
^C^Carea;a;o;
second
it works then.
can someone please help me...:cry:
grtzz Pat
I can get it to end the area command, but now its not registering an area... :geek:
^C^Carea;a;o;\;;Text;\;$m=$(/,$(fix,$(/,$(getvar,area),10000)),100)m²;
I now remember why I hate LT...
jep the command ends, but it only shows 1 area.
try the macro ^C^Carea;a;o; it accumulates the area's to 1, that's the nice part.
  • 6 years later...
I am using this macro to insert areas of closed polyline shapes.
It works very well except that it uses the default text style and height.
Please tell me how to include a text height instruction into the macro.
I have tried a number of things but none of them work.
A text height is asked if the current text style is not set to a fixed height ie 0.0. So you need to set the correct style to be used, Style S textstyle. In lisp I check for this and use correct style.
Lee a question o;\;; or o;;\; you have to cancel the pick object select before moving on.
