BLOACH85 Posted May 26, 2009 Share Posted May 26, 2009 Is there anyway to make an edited dimension stand out from non edited? such as a text box under a non plotting layer or some sort of identification? if so does anyone know where to start with a routine like that? Quote Link to comment Share on other sites More sharing options...
JohnM Posted May 26, 2009 Share Posted May 26, 2009 this will turn the dimension text to red for all over ride text change the interger to what color you like. (defun c:dov (/ ss cnt obj) (setq ss (ssget "X" '((0 . "DIMENSION")(-4 . "<NOT") (1 . "")(-4 . "NOT>"))));_get all over ride dim objects (setq cnt 0) (if ss (repeat (sslength ss) (setq obj (vlax-ename->vla-object (ssname ss cnt)) cnt (1+ cnt) ) (vla-put-TextColor obj 1) ; 1 = red );_repeat );_if (princ) );_defun Quote Link to comment Share on other sites More sharing options...
BLOACH85 Posted May 27, 2009 Author Share Posted May 27, 2009 Thanks JohnM now I wan to understand how this was written because i just had crazy amounts of trouble. Quote Link to comment Share on other sites More sharing options...
BLOACH85 Posted May 27, 2009 Author Share Posted May 27, 2009 Now this is using vla format but its just checking the selection to see whiich dims are overriden correct? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 27, 2009 Share Posted May 27, 2009 The selection set is filtered to only allow OverRidden Dimensions, then the colour is changed for each of these. Quote Link to comment Share on other sites More sharing options...
BLOACH85 Posted May 27, 2009 Author Share Posted May 27, 2009 Gotcha i understand that now i was just making it way more complicated than needed Quote Link to comment Share on other sites More sharing options...
JohnM Posted May 27, 2009 Share Posted May 27, 2009 It takes a few hundred programs before you start thinking of the simplest way to write code. Like the code that I submitted. I want to gather all dimensions that have been over written I want to make them unique. The first statement is almost simple except you would have to know that the “over written” part is a property The second statement is simple but not defined enough. The word unique leaves too much for the imagination. You need to learn how to define an action down to a definitive action. Once you train your self to define actions in extreme detail the coding becomes clearer to you and hopefully easer to write. Also, it helps to know as much as possible about an object and it’s properties. The more you know the easer it is to figure out a simple way to change it. If you spend some time clicking on various objects and looking at the available properties in the properties dialog box you will gain a better knowledge of the objects. Quote Link to comment Share on other sites More sharing options...
BLOACH85 Posted May 27, 2009 Author Share Posted May 27, 2009 Thanks Guys Quote Link to comment Share on other sites More sharing options...
mrsecret Posted May 5, 2015 Share Posted May 5, 2015 Heay there, can you tell what is the command for this lisp. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 5, 2015 Share Posted May 5, 2015 Heay there, can you tell what is the command for this lisp. Maybe the one in red? (defun c:dov (/ ss cnt obj) Quote Link to comment Share on other sites More sharing options...
mrsecret Posted May 7, 2015 Share Posted May 7, 2015 Thank you it works Quote Link to comment Share on other sites More sharing options...
